Has anyone had issues with Dashboard Deployment/Preview not correlating with what Customize Tracker View has Saved?
I’ve been creating a custom Tracker with a bunch of fields. Each time I add something, I save the Tracker View, check the Preview under deployment, and if everything looks good, I save the Dashboard. I’ve been rinsing and repeating this all day, and was about 3/4 of the way through when all of a sudden every control I create Previews as if it were a white input field (we’re using classic shell), even though it looks correct on the dashboard itself and the Properties show that it’s a tracker query control. I’ve tried everything I can think of, including re-importing an earlier save, and it still does the same thing. I did try deploying it just in case it was some quirk of the Preview function, and it’s not. The new fields are not behaving correctly. Anyone experience this before?
