Dashboard Tracker ComboBox weird behavior
I have a classic UX dashboard that I have added a combo box tracker to filter ProdGrup.ProdCode. I have 2 grids showing the quote headers and another to show the quote details when the header is selected. The baq query for the quote header grid has a sales group field that is a calculated field which finds the ProdCode of the first detail line. I have added a combo box tracker to the quote header grid which prefills with al the product groups using a Erp.Adapters.Controls.ProdGrupCombo. This combo box fills correctly, but when I select a group to filter on, it takes a while to complete and return all quote details lines in the systems that belong to the selected product group, the quote header grid remains empty. Is there a better way to do this? Why is the tracker on one grid filtering the other grid?
If you are using the same query, (I can’t see your dashboard elements, so I don’t know what you have set up), a tracker is for the query, not for the grid. So if you want those separately filtered, you need to bring in the same query twice.
As far as the drop down, I would see if you can set the like property in the BAQ and see if the dashboard automatically gives you the drop down.
If that doesn’t work I would still do the changes in the BAQ by making the BAQ update able, make it “Advanced BPM Only” then you have access to the advanced column editor, and you can set the acceptable fields there. I usually use another BAQ.
I usually avoid “Customizing” the dashboard for drop downs, because it makes it hard to change later, and it’s actually easier to just make the adjustments in the BAQ.
Here’s how to make a BAQ automatically give custom drop downs. This will work for the tracker filters, even if you don’t use any update functionality.
Sorry, I didn’t give all the information.The top query list all quotes based on the trackers. The bottom query displays the details of the selected quote from the top query. Selecting the Sales Group tracker combo box is filtering the bottom query, returning all quote detail lines that match the selected product group. The top quote list is empty.
Quote List Query
select [SalesRep].[Name] as [SalesRep_Name],
       [QuoteHed].[Quoted] as [QuoteHed_Quoted],
       [QuoteHed].[FollowUpDate] as [QuoteHed_FollowUpDate],
       [QuoteHed].[QuoteNum] as [QuoteHed_QuoteNum],
       [QuoteHed].[ParentQuoteNum] as [QuoteHed_ParentQuoteNum],
       [CustGrup].[GroupDesc] as [CustGrup_GroupDesc],
            select top (1)
                [ProdGrup].[Description] as [ProdGrup_Description]
            from Erp.QuoteDtl as QuoteDtl3
                left outer join Erp.ProdGrup as ProdGrup
                    on QuoteDtl3.Company = ProdGrup.Company
                       and QuoteDtl3.ProdCode = ProdGrup.ProdCode
            where (QuoteDtl3.QuoteNum = QuoteHed.QuoteNum)
       ) as [Calculated_SalesGroup],
       [Customer].[CustID] as [Customer_CustID],
       [Customer].[Name] as [Customer_Name],
       [QuoteHed].[CustRef_c] as [QuoteHed_CustRef_c],
       (IsNull(QuoteCnt.Name, '')) as [Calculated_CustomerContact],
       [QuoteHed].[DueDate] as [QuoteHed_DueDate],
       [QuoteHed].[DateQuoted] as [QuoteHed_DateQuoted],
       [QuoteHed].[ExpirationDate] as [QuoteHed_ExpirationDate],
       [QuoteHed].[ConfidencePct] as [QuoteHed_ConfidencePct],
       [QuoteHed].[CurrencyCode] as [QuoteHed_CurrencyCode],
       [QuoteHed].[QuoteAmt] as [QuoteHed_QuoteAmt],
       [QuoteHed].[DocTotalPotential] as [QuoteHed_DocTotalPotential],
       [SubQuery3].[Calculated_FreightPackagingPrice] as [Calculated_FreightPackagingPrice],
       [SubQuery3].[Calculated_DocFreightPackagingPrice] as [Calculated_DocFreightPackagingPrice],
       [SubQuery2].[Calculated_totalMtlCost] as [Calculated_totalMtlCost],
       [SubQuery2].[Calculated_totalMtlBurCost] as [Calculated_totalMtlBurCost],
       [SubQuery4].[Calculated_totalLabourCost] as [Calculated_totalLabourCost],
       [SubQuery4].[Calculated_totalBurdenCost] as [Calculated_totalBurdenCost],
       [SubQuery4].[Calculated_totalSubcontractCost] as [Calculated_totalSubcontractCost],
       ((IsNull(SubQuery4.Calculated_totalBurdenCost, 0) + IsNull(SubQuery4.Calculated_totalLabourCost, 0)
         + IsNull(SubQuery2.Calculated_totalMtlCost, 0) + IsNull(SubQuery4.Calculated_totalSubcontractCost, 0)
         + IsNull(SubQuery2.Calculated_totalMtlBurCost, 0)
       ) as [Calculated_totalCost],
       ((QuoteHed.QuoteAmt - IsNull(SubQuery3.Calculated_FreightPackagingPrice, 0) - totalCost)) as [Calculated_EstMarginCost],
       ((case
             when (QuoteHed.QuoteAmt - IsNull(SubQuery3.Calculated_FreightPackagingPrice, 0)) > 0 then
                 EstMarginCost / (QuoteHed.QuoteAmt - IsNull(SubQuery3.Calculated_FreightPackagingPrice, 0))
             else
                 0
         end
       ) as [Calculated_EstMarginPerc],
       [QuoteHed].[CurrentStage] as [QuoteHed_CurrentStage],
       ((case
             when QuoteHed.Ordered = 1 then
                 'WON'
             else
         end
       ) as [Calculated_FlagWon],
       (case
            when IsNull(SubQuery10.Task_Conclusion, 'NEXT') = 'WIN'
                 and QuoteHed.Ordered = 1 then
                'WON'
                 and QuoteHed.Ordered = 0 then
                'LOST'
            when IsNull(SubQuery10.Task_Conclusion, 'NEXT') = 'LOSE' then
                'LOST'
            when IsNull(SubQuery10.Task_Conclusion, 'NEXT') = 'NEXT' then
                'OPEN'
            else
        end
       ) as [Calculated_OrderStatus],
       [SubQuery10].[Calculated_TaskReason] as [Calculated_TaskReason],
       [SalesRep].[SalesRepCode] as [SalesRep_SalesRepCode],
       [Customer].[CustNum] as [Customer_CustNum],
       [Customer].[GroupCode] as [Customer_GroupCode],
       ((case
                 EstMarginCost / (QuoteHed.QuoteAmt - IsNull(SubQuery3.Calculated_FreightPackagingPrice, 0)) * 100
             else
                 0
         end
       ) as [Calculated_MarginPerc],
       (IsNull(UDCodes.CodeDesc, '')) as [Calculated_QuoteType],
       [QuoteHed].[EntryDate] as [QuoteHed_EntryDate],
       (datepart(year, QuoteHed.EntryDate)) as [Calculated_EntryYear]
from Erp.QuoteHed as QuoteHed
    left outer join Erp.QSalesRP as QSalesRP
        on QuoteHed.Company = QSalesRP.Company
           and QuoteHed.QuoteNum = QSalesRP.QuoteNum
           and (QSalesRP.PrimeRep = 1)
    inner join Erp.SalesRep as SalesRep
        on QSalesRP.Company = SalesRep.Company
           and QSalesRP.SalesRepCode = SalesRep.SalesRepCode
    inner join Erp.Customer as Customer
        on QuoteHed.Company = Customer.Company
           and QuoteHed.CustNum = Customer.CustNum
    left outer join Erp.CustGrup as CustGrup
        on Customer.Company = CustGrup.Company
           and Customer.GroupCode = CustGrup.GroupCode
    left outer join Erp.QuoteCnt as QuoteCnt
        on QuoteHed.Company = QuoteCnt.Company
           and QuoteHed.QuoteNum = QuoteCnt.QuoteNum
           and (QuoteCnt.PrimeContact = 1)
    inner join
        select [QuoteHed1].[QuoteNum] as [QuoteHed1_QuoteNum],
               (Sum(QuoteDtl1.DocExtPriceDtl)) as [Calculated_DocFreightPackagingPrice],
               (Sum(QuoteDtl1.ExtPriceDtl)) as [Calculated_FreightPackagingPrice]
        from Erp.QuoteHed as QuoteHed1
            left outer join Erp.QuoteDtl as QuoteDtl1
                on QuoteHed1.Company = QuoteDtl1.Company
                   and QuoteHed1.QuoteNum = QuoteDtl1.QuoteNum
                   and (
                           QuoteDtl1.PartNum = 'FRTI'
                           or QuoteDtl1.PartNum = 'FRTP'
        group by [QuoteHed1].[QuoteNum]
    ) as SubQuery3
        on QuoteHed.QuoteNum = SubQuery3.QuoteHed1_QuoteNum
    left outer join
        select [QuoteDtl2].[QuoteNum] as [QuoteDtl2_QuoteNum],
               (Sum(QuoteOpr.ProdLabRate * QuoteOpr.QtyPer * QuoteOpr.ProdStandard * QuoteDtl2.SellingExpectedQty)) as [Calculated_totalLabourCost],
               (sum(QuoteOpr.ProdBurRate * QuoteOpr.QtyPer * QuoteOpr.ProdStandard * QuoteDtl2.SellingExpectedQty)) as [Calculated_totalBurdenCost],
               (Sum(QuoteOpr.EstUnitCost * QuoteOpr.QtyPer * QuoteDtl2.SellingExpectedQty)) as [Calculated_totalSubcontractCost]
        from Erp.QuoteOpr as QuoteOpr
            inner join Erp.QuoteDtl as QuoteDtl2
                on QuoteOpr.Company = QuoteDtl2.Company
                   and QuoteOpr.QuoteNum = QuoteDtl2.QuoteNum
                   and QuoteOpr.QuoteLine = QuoteDtl2.QuoteLine
        group by [QuoteDtl2].[QuoteNum]
    ) as SubQuery4
        on QuoteHed.QuoteNum = SubQuery4.QuoteDtl2_QuoteNum
    left outer join
        select [QuoteMtl].[QuoteNum] as [QuoteMtl_QuoteNum],
               (Sum(QuoteMtl.QtyPer * QuoteMtl.EstMtlUnitCost / SubQuery6.Calculated_ConvToBase
                    * SubQuery7.Calculated_ConvFromBase * QuoteDtl.SellingExpectedQty
               ) as [Calculated_totalMtlCost],
               (Sum(quotemtl.qtyper * quotemtl.EstMtlBurUnitCost / SubQuery6.Calculated_ConvToBase
               ) as [Calculated_totalMtlBurCost]
        from Erp.QuoteMtl as QuoteMtl
            left outer join
                select distinct
                    [QuoteMtl1].[Company] as [QuoteMtl1_Company],
                    [QuoteMtl1].[QuoteNum] as [QuoteMtl1_QuoteNum],
                    [QuoteMtl1].[PartNum] as [QuoteMtl1_PartNum],
                    [Part].[IUM] as [Part_IUM],
                    (IsNull(PartUOM.ConvFactor, 1)) as [Calculated_ConvToBase]
                from Erp.PartUOM as PartUOM
                    right outer join Erp.Part as Part
                        on PartUOM.Company = Part.Company
                           and PartUOM.PartNum = Part.PartNum
                           and PartUOM.UOMCode = Part.IUM
                    right outer join Erp.QuoteMtl as QuoteMtl1
                        on Part.Company = QuoteMtl1.Company
                           and Part.PartNum = QuoteMtl1.PartNum
            ) as SubQuery6
                on QuoteMtl.Company = SubQuery6.QuoteMtl1_Company
                   and QuoteMtl.QuoteNum = SubQuery6.QuoteMtl1_QuoteNum
                   and QuoteMtl.PartNum = SubQuery6.QuoteMtl1_PartNum
            left outer join
                select distinct
                    [QuoteMtl4].[Company] as [QuoteMtl4_Company],
                    [QuoteMtl4].[QuoteNum] as [QuoteMtl4_QuoteNum],
                    [QuoteMtl4].[PartNum] as [QuoteMtl4_PartNum],
                    [QuoteMtl4].[IUM] as [QuoteMtl4_IUM],
                    (IsNull(PartUOM1.ConvFactor, 1)) as [Calculated_ConvFromBase]
                from Erp.QuoteMtl as QuoteMtl4
                    left outer join Erp.PartUOM as PartUOM1
                        on QuoteMtl4.Company = PartUOM1.Company
                           and QuoteMtl4.PartNum = PartUOM1.PartNum
                           and QuoteMtl4.IUM = PartUOM1.UOMCode
            ) as SubQuery7
                on QuoteMtl.Company = SubQuery7.QuoteMtl4_Company
                   and QuoteMtl.QuoteNum = SubQuery7.QuoteMtl4_QuoteNum
                   and QuoteMtl.PartNum = SubQuery7.QuoteMtl4_PartNum
                   and QuoteMtl.IUM = SubQuery7.QuoteMtl4_IUM
                on QuoteMtl.Company = QuoteDtl.Company
                   and QuoteMtl.QuoteNum = QuoteDtl.QuoteNum
                   and QuoteMtl.QuoteLine = QuoteDtl.QuoteLine
        group by [QuoteMtl].[QuoteNum]
    ) as SubQuery2
        on QuoteHed.QuoteNum = SubQuery2.QuoteMtl_QuoteNum
    left outer join
        select [Task].[Company] as [Task_Company],
               [Task].[Key1] as [Task_Key1],
               [Task].[TaskQuoteNum] as [Task_TaskQuoteNum],
               [Task].[TaskSeqNum] as [Task_TaskSeqNum],
               [Task].[Conclusion] as [Task_Conclusion],
               (IsNull(Reason.Description, '')) as [Calculated_TaskReason]
        from Erp.Task as Task
            inner join
                select [Task1].[Company] as [Task1_Company],
                       [Task1].[Key1] as [Task1_Key1],
                       (Max(Task1.TaskSeqNum)) as [Calculated_MaxSeq]
                from Erp.Task as Task1
                where (Task1.RelatedToFile = 'QuoteHed')
                group by [Task1].[Company],
                         [Task1].[Key1]
            ) as SubQuery9
                on Task.Company = SubQuery9.Task1_Company
                   and Task.Key1 = SubQuery9.Task1_Key1
                   and Task.TaskSeqNum = SubQuery9.Calculated_MaxSeq
            left outer join Erp.Reason as Reason
                on Task.Company = Reason.Company
                   and Task.ReasonCode = Reason.ReasonCode
    ) as SubQuery10
        on QuoteHed.Company = SubQuery10.Task_Company
           and QuoteHed.QuoteNum = SubQuery10.Task_TaskQuoteNum
    left outer join Ice.UDCodes as UDCodes
        on QuoteHed.QuoteType_c = UDCodes.CodeID
           and (UDCodes.CodeTypeID = 'QuoteType')
order by QuoteHed.FollowUpDate,
         Customer.Name,
         QuoteHed.QuoteNum
Quote Detail Query
select [QuoteDtl].[QuoteNum] as [QuoteDtl_QuoteNum],
       [QuoteDtl].[QuoteLine] as [QuoteDtl_QuoteLine],
       [QuoteDtl].[SellingExpectedQty] as [QuoteDtl_SellingExpectedQty],
       [QuoteDtl].[PartNum] as [QuoteDtl_PartNum],
       [QuoteDtl].[DocExtPriceDtl] as [QuoteDtl_DocExtPriceDtl],
       ((case
             when QuoteDtl.ExtPriceDtl > 0 then
       (QuoteDtl.ExtPriceDtl - totalCost) / QuoteDtl.ExtPriceDtl
             else
                 0
         end
       (QuoteDtl.SellingExpectedQty
        * (IsNull(SubQuery4.Calculated_totalBurdenCost, 0) + IsNull(SubQuery4.Calculated_totalLabourCost, 0)
       [SubQuery4].[Calculated_totalLabourHrs] as [Calculated_totalLabourHrs],
       ((QuoteDtl.ExtPriceDtl - totalCost)) as [Calculated_EstMarginCost],
       ((case
             when IsNull(SubQuery4.Calculated_totalLabourHrs, 0) > 0 then
                 QuoteDtl.ExtPriceDtl / SubQuery4.Calculated_totalLabourHrs
             else
                 0
         end
       ) as [Calculated_shippedPerHr],
       ((case
                 EstMarginCost / SubQuery4.Calculated_totalLabourHrs
             else
                 0
         end
       ) as [Calculated_MarginPerHr],
       ((case
       (QuoteDtl.ExtPriceDtl - totalCost) / QuoteDtl.ExtPriceDtl * 100
             else
                 0
         end
    inner join Erp.QuoteHed as QuoteHed
        on QuoteDtl.Company = QuoteHed.Company
           and QuoteDtl.QuoteNum = QuoteHed.QuoteNum
    left outer join
        select [QuoteHed3].[QuoteNum] as [QuoteHed3_QuoteNum],
               [QuoteMtl].[QuoteLine] as [QuoteMtl_QuoteLine],
        from Erp.QuoteHed as QuoteHed3
            inner join Erp.QuoteMtl as QuoteMtl
                on QuoteHed3.Company = QuoteMtl.Company
                   and QuoteHed3.QuoteNum = QuoteMtl.QuoteNum
            left outer join
                select distinct
                    [QuoteMtl1].[QuoteLine] as [QuoteMtl1_QuoteLine],
            ) as SubQuery6
                   and QuoteMtl.QuoteLine = SubQuery6.QuoteMtl1_QuoteLine
            left outer join
                select distinct
                    [QuoteMtl4].[QuoteLine] as [QuoteMtl4_QuoteLine],
            ) as SubQuery7
                   and QuoteMtl.QuoteLine = SubQuery7.QuoteMtl4_QuoteLine
        group by [QuoteHed3].[QuoteNum],
    ) as SubQuery2
        on QuoteDtl.QuoteNum = SubQuery2.QuoteHed3_QuoteNum
           and QuoteDtl.QuoteLine = SubQuery2.QuoteMtl_QuoteLine
    left outer join
               [QuoteDtl1].[QuoteLine] as [QuoteDtl1_QuoteLine],
                   and (
        group by [QuoteHed1].[QuoteNum],
    ) as SubQuery3
        on QuoteDtl.QuoteNum = SubQuery3.QuoteHed1_QuoteNum
           and QuoteDtl.QuoteLine = SubQuery3.QuoteDtl1_QuoteLine
    left outer join
        select [QuoteHed2].[QuoteNum] as [QuoteHed2_QuoteNum],
               [QuoteOpr].[QuoteLine] as [QuoteOpr_QuoteLine],
               (Sum(QuoteOpr.ProdLabRate * QuoteOpr.QtyPer * QuoteOpr.ProdStandard)) as [Calculated_totalLabourCost],
               (sum(QuoteOpr.ProdBurRate * QuoteOpr.QtyPer * QuoteOpr.ProdStandard)) as [Calculated_totalBurdenCost],
               (Sum(QuoteOpr.EstUnitCost * QuoteOpr.QtyPer)) as [Calculated_totalSubcontractCost],
               (Sum(QuoteOpr.QtyPer * QuoteOpr.ProdStandard)) as [Calculated_totalLabourHrs]
        from Erp.QuoteHed as QuoteHed2
            inner join Erp.QuoteOpr as QuoteOpr
                on QuoteHed2.Company = QuoteOpr.Company
                   and QuoteHed2.QuoteNum = QuoteOpr.QuoteNum
        group by [QuoteHed2].[QuoteNum],
    ) as SubQuery4
        on QuoteDtl.QuoteNum = SubQuery4.QuoteHed2_QuoteNum
           and QuoteDtl.QuoteLine = SubQuery4.QuoteOpr_QuoteLine
So when you return nothing on the publishing grid, that’s like not filtering the subscribed grid at all. So you’re drop down isn’t filtering the top grid.
It’s probably because your value is the code, but the displayed is the description and it’s not matching up somewhere. The second query showing all is a symptom of your original problem in that the filter isn’t correctly.
If it were me, I would delete the customized tracker, start a new one with just the basic selections in the tracker setup screen. For the drop downs you want, use the BAQ adjustment that I showed you. First, try the like fields, if those don’t work, then the updateable trick.
Thank You. I never knew about this, what a time saver and no frustration using customized trackers.
