Hi All,
I am developing a simple dashboard in Epicor 9. It is linked to an External BAQ which is pulling data from sql view.
The dashboard seems to work fine in design mode. But when I am hitting the ‘Test Application’ button on Deploy Dashboard, it is throwing this compile error:
--------compile errors------------
Error: CS1002 - line 68 (67) - ; expected
Error: CS1002 - line 69 (68) - ; expected
Error: CS1525 - line 69 (68) - Invalid expression term ‘.’
Error: CS1026 - line 70 (69) - ) expected
Error: CS1002 - line 70 (69) - ; expected
Error: CS1525 - line 70 (69) - Invalid expression term ‘)’
Error: CS1002 - line 71 (70) - ; expected
Error: CS1002 - line 72 (71) - ; expected
Error: CS1525 - line 72 (71) - Invalid expression term ‘.’
Error: CS1026 - line 73 (72) - ) expected
Error: CS1002 - line 73 (72) - ; expected
Error: CS1525 - line 73 (72) - Invalid expression term ‘)’
** Compile Failed. **
I haven’t written any custom code so I am not sure what above errors are about.
Any idea?
Thanks.
