Dashboard Report Maintenance
Hi Group,
I had the same problem and gave up on using BAQs for reporting so I
would interested in the answer as well.
Linda
Of bonner.nathan
Sent: Wednesday, December 10, 2008 9:19 AM
Subject: [Vantage] Dashboard Report Maintenance
I have created a dashboard that uses three unique BAQ's as separate
Dashboard Quarries. From the combination of these three BAQ's used
on the Dashboard I am trying to create a Dashboard Report linked to
the Dashboard.
1) I have successfully built the RPT using one BAQ as the primary and
the other two in sub reports.
2) The sample XML data generates and is placed in the correct
location for sample XML's
3) The Report runs beautifully in Dashboard DEVELOPER mode
(apparently against the sample XML though)
4) BUT THE REPORT WILL NOT GENERATE WHEN DEVELOPER IS TURNED OFF AND
THE DASHBOARD RELAUNCHED.
Q1) Where are Dashboard Report XML files supposed to be generated
when run in production?
Q2) Why will a dashboard report run fine in DEVELOPER but fail in
production?
Q3) Has anyone had any luck with Dashboard Reports using multiple
BAQ's???
Thanks in advance for any help,
Nathan Bonner
the Dashboard.
production?
BAQ's???
Nathan Bonner
