Dashboard Refresh after tab out of EpiTextBox
I created a dashboard and would like it to refresh after a tab out of the EpiTextBox.
I created a Leave event like this.
    private static void txtOrderDtl_PartNum_Leave(object sender, System.EventArgs args)
       System.Reflection.MethodInfo methInfo = DBTVP_b46d4703_b1ad_485c_8e8c_5909d4f5f27d.GetType().GetMethod("RefreshDB", System.Reflection.BindingFlags.Instance | System.Reflection.BindingFlags.NonPublic);
        if ((methInfo != null))
          methInfo.Invoke(DBTVP_b46d4703_b1ad_485c_8e8c_5909d4f5f27d, null);
When I go to ā€œTest Applicationā€ of the Dashboard Deploy I get the error:
The name ā€˜methInfoā€™ does not exist in the current context
How can I refresh after a tab out of a field on the dashboard.
Use this code instead.
MainController.AppControlPanel.HandleToolClick("RefreshTool", new
Infragistics.Win.UltraWinToolbars.ToolClickEventArgs(MainController.MainToolManager.Tools["RefreshTool"], null));
Hi @maverick
have you tried this event on your EpiTextBox
Are you trying to do this before you deploy it? You canā€™t do this in the runtime. You have to deploy it first, then do a customization on the deployed dashboard. Sorry I didnā€™t catch that first.
This is done before I deploy. What can be used once it is deployed?
After itā€™s deployed, you can get the (mostly) full suite of customization tools. Pretty much just like a regular form. There a few exceptions, but I havenā€™t really run into them. Most of the limitationā€™s are convenience in that the regular forms are already populating temporary tables. But thatā€™s way down the road of complexity.
