Ben,
I am on my way out the door, so this is untested, but something like below
should do the trick.
You may have to play with the syntax a bit.
for each PartPlant Where PartPlant.Company = cur-comp no-lock,
each PartWhse Where PartWhse.Company = PartPlant.Company
and PartWhse.PartNum = PartPlant.PartNum
and PartWhse.WarehouseCode = "Raw"
and PartWhse.OnHandQty > 0
or PartWhse.Company = PartPlant.Company
and PartWhse.WarehouseCode <> "RAW"
no-lock,
each Part Where Part.Company = PartWhse.Company
and Part.PartNum = PartWhse.PartNum
and Part.NonStock = no and
Part.TypeCode = 'M' no-lock
BY Part.PartNum:
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of bbelzer42
Sent: Wednesday, June 22, 2005 4:47 PM
Subject: [Vantage] Re: Dashboard Query
Oops... left the code out:
no-lock,
BY Part.PartNum:
Thanks! Ben
no-lock,
BY Part.PartNum:
Good luck,
Aaron Hoyt
Vantage Plastics
Of bbelzer42
no-lock,
BY Part.PartNum:
Thanks! Ben
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@v...> wrote:
> Ben,
> You can add a filter in the query where the linking is done.
> For instance where you call the PartWhse table,
> Add a line that reads... PartWhse.OnHandQty > 0
> If you need more detail, post the contents of your query.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
> Of bbelzer42
> Sent: Wednesday, June 22, 2005 3:23 PM
> Subject: [Vantage] Dashboard Query
> I have a dashboard query that shows me everything I have on hand for a
> part. It shows the part twice (two lines) if it is in 2 warehouses.
> Is there a way to keep a line from showing? Ie: If the Warehouse has
> 0 on hand, can I make the line not show?
> Thanks,
> Ben
must have
Builder and
> Yahoo! Groups Links
Yahoo! Groups Links
