Dashboard OR filtering
Thanks, that will work.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dan Godfrey
Sent: Friday, January 31, 2014 1:27 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] RE: Dashboard OR filtering
Why not create an outlier Calcfield.  I would use the 2% and -5% calculations to determine a logical (True or False) field.  So in the dashboard you can have a more simple filter on the logical Calcfield.  I might even show two calcfields one for the 2% and one for the -5%.  This just give more flexibility in the dashboard.
I have had to do it this way since dashboards do not have the ‘OR’ option, all dashboard filters are ‘AND’-wise.  I use calcfields many times for the developer side and just don’t show the field.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Greg Payne
Sent: Friday, January 31, 2014 9:27 AM
Subject: [Vantage] Dashboard OR filtering
In a dashboard I have a calculated percentage. I only want to show the records that are greater than 2 % or less than -5 %.
It works with the or filtering in the baq, but I can only get on or the other in the dashboard.
Thanks for any guidance.
Greg
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
------------------------------------------------------------------------------------------------------------------------ CONFIDENTIALITY NOTICE: The data attached/enclosed may contain information (including technology and technical data) which is subject to the U.S. International Traffic in Arms Regulations (ITAR) or Export Administration Regulations (EAR). This information may not be exported, released, or disclosed to foreign persons either inside or outside the United States without first obtaining the proper U.S. export license or written authorization. In addition, the information and articles described herein are either patented or proprietary, and the copying or reproduction thereof is prohibited without ADVANCED Motion Controls prior written consent. If you are not the intended recipient (or have received this e-mail in error), please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden. Thank you for your compliance. X3BTB534
Greg
Greg
