Is there a good way to allow a dashboard to have the option for “both” for a boolen (checkbox) field?
If you have a search parameter for a character field in a dashboard, leaving it blank means to ignore that filter. But checkboxes only have “checked” and “unchecked” states. There is no “unselected” checkbox state.
So how do you make a dashboard with a checkbox field search, to be able to choose: “checked”, “unchecked”, or “both”?
What I do is to make a calculated field (of type char) in the BAQ, and have it be a combination of the bit field’s state and a common letter. Like
ActiveStatus = (case when Part,InActive = 1 then 'IB' else 'AB" end)
Then in the dashboard’s tracker pane, have an input for ActiveStatus
with the condition MATCHES. Then have the label for that field be
Status (I|A|B):
if it is I, it returns only records where Part.InActive is true
if it is A, it returns only records where Part.InActive is false
If its blank OR is B, it returns all records regardless of the value in Part.InActive
Is there a better way to have a boolean field as a search parameter, but with the option for “don’t care” ?
