The InitializeLayout does not work, even though I get no errors:
easier to read the code now......
Public Class Script
Dim WithEvents myGrid as EpiUltraGrid
' ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
' Begin Wizard Added Module Level Variables **
' End Wizard Added Module Level Variables **
' Add Custom Module Level Variables Here **
Public Sub InitializeCustomCode()
' ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Initialization' lines **
' Begin Wizard Added Variable Initialization
' End Wizard Added Variable Initialization
' Begin Wizard Added Custom Method Calls
' End Wizard Added Custom Method Calls
' Begin Custom Code
myGrid = CType(csm.GetNativeControlReference("f78f6a5b-6ea2-4a8c-a72b-b50aa59be9ac"),EpiUltraGrid)
AddHandler myGrid.InitializeLayout , AddressOf myGrid_InitializeLayout
' End Custom Code
End Sub
Public Sub DestroyCustomCode()
' ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
' Begin Wizard Added Object Disposal
'RemoveHandler Me.V_UFPT_QuotePipeHasDocs_1View_Row.EpiRowChanged, AddressOf Me.V_UFPT_QuotePipeHasDocs_1View_AfterRowChange
' End Wizard Added Object Disposal
' Begin Custom Code Disposal
' AddHandler myGrid.InitializeLayout , AddressOf myGrid_InitializeLayout
' End Custom Code Disposal
End Sub
Private Sub MainController_Load(ByVal sender As Object, ByVal args As EventArgs)
' Add Event Handler Code
MessageBox.Show("load")
'myGrid = CType(csm.GetNativeControlReference("f78f6a5b-6ea2-4a8c-a72b-b50aa59be9ac"),EpiUltraGrid)
'Dim myGrid as EpiUltraGrid = CType(csm.GetNativeControlReference("f78f6a5b-6ea2-4a8c-a72b-b50aa59be9ac"),EpiUltraGrid)
myGrid.DisplayLayout.Bands(0).Columns.Add("test","test")
Dim dsNewmyGrid as system.data.dataview = myGrid.DataSource
Dim dr as datarow
Dim tURL as String
For Each dr in dsNewmyGrid.Table.Rows
tURL = dr.Item("QuoteHed.ShortChar10")
'MessageBox.Show(tURL)
Next
MessageBox.Show("after load")
End Sub
Private Sub myGrid_InitializeLayout(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles myGrid.InitializeLayout
MessageBox.Show("initialize layout")
e.Layout.Bands(0).Columns(0).CellActivation = Infragistics.Win.UltraWinGrid.Activation.ActivateOnly
e.Layout.Bands(0).Columns(0).CellAppearance.ForeColor = Color.Blue
e.Layout.Bands(0).Columns(0).CellAppearance.FontData.Underline = Infragistics.Win.DefaultableBoolean.True
e.Layout.Bands(0).Columns(0).CellAppearance.Cursor = Cursors.Hand
End Sub
Public Class Script
' Begin Custom Code
' End Custom Code
End Sub
End Sub
Dim dr as datarow
Dim tURL as String
Next
End Sub
End Sub
--- In vantage@yahoogroups.com, "tomdomurat" <tomdomurat@...> wrote:
> The declarations seems to work now, thanks.
> However, the InitializeLayout event does not work(??) I don't get any
> errors, but it doesn't work either.
> Here is the complete code:
> Public Class ScriptDim WithEvents myGrid as EpiUltraGrid ' ** Wizard
> Variables' Comments! ** ' Begin Wizard Added Module Level Variables ** '
> End Wizard Added Module Level Variables ** ' Add Custom Module Level
> Variables Here ** Public Sub InitializeCustomCode() ' ** Wizard Insert
> Initialization' lines ** ' Begin Wizard Added Variable Initialization
> ' End Wizard Added Variable Initialization ' Begin Wizard Added Custom
> Method Calls ' End Wizard Added Custom Method Calls ' Begin Custom
> Code myGrid =
> CType(csm.GetNativeControlReference("f78f6a5b-6ea2-4a8c-a72b-b50aa59be9a\
> c"),EpiUltraGrid) AddHandler myGrid.InitializeLayout , AddressOf
> myGrid_InitializeLayout ' End Custom Code End Sub Public Sub
> DestroyCustomCode() ' ** Wizard Insert Location - Do not delete
> 'Begin/End Wizard Added Object Disposal' lines ** ' Begin Wizard Added
> Object Disposal 'RemoveHandler
> Me.V_UFPT_QuotePipeHasDocs_1View_AfterRowChange ' End Wizard Added
> Object Disposal ' Begin Custom Code Disposal ' AddHandler
> myGrid.InitializeLayout , AddressOf myGrid_InitializeLayout ' End
> Custom Code Disposal End Sub
> EventArgs) ' Add Event Handler Code MessageBox.Show("load") 'myGrid =
> c"),EpiUltraGrid) 'Dim myGrid as EpiUltraGrid =
> c"),EpiUltraGrid)
> myGrid.DisplayLayout.Bands(0).Columns.Add("test","test") Dim
> dsNewmyGrid as system.data.dataview = myGrid.DataSource Dim dr as
> datarow Dim tURL as String For Each dr in dsNewmyGrid.Table.Rows tURL =
> dr.Item("QuoteHed.ShortChar10") 'MessageBox.Show(tURL) Next
> MessageBox.Show("after load") End SubPrivate Sub
> myGrid.InitializeLayout MessageBox.Show("initialize layout")
> e.Layout.Bands(0).Columns(0).CellAppearance.Cursor = Cursors.HandEnd Sub
> In vantage@yahoogroups.com, "Anon" <epicor-team@> wrote:>
> > I think you have to declare it like this:
> > At the very very top just below the class identifier. Then in the
> InitializeCustomCode() you would want to do:
> > myGrid =
> c"),EpiUltraGrid)
> > And then of course make sure to dispose of it in the Destroy.
> > --- In vantage@yahoogroups.com, "tomdomurat" tomdomurat@ wrote:
> > > I tried that and get the following error. BTW, this is on the Load
> event of a customized Dashboard.
> > > I also tried declaring "myGrid" outside the Sub, everything compiles
> but then the dashboard throws invocation error when loading.
> As EventArgs)
> > > Dim WithEvents myGrid as EpiUltraGrid =
> c"),EpiUltraGrid)
> > > Compiling Custom Code ...
> > > ----------errors------------
> > > Error: BC30247 - line 66 (142) - 'WithEvents' is not valid on a
> local variable declaration.
> > > --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > > > When you instantiate the grid you need to declare it 'WithEvents'.
> > > > *John Driggers*
> > > > *Chief Data Wrangler*
> > > > *I have an Epicor blog <http://usdoingstuff.com/>. How useful is
> that?*
> > > > *:: 904.404.9233
> > > > :: waffqle@
> > > > :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> > > > On Thu, Oct 11, 2012 at 12:00 PM, tomdomurat <tomdomurat@> wrote:
> > > > > Trying to change the appearance of the Dashboard using the
> > > > > InitializeLayout. See the code and error below:
> > > > > Imports Infragistics.Win
> > > > > Imports Infragistics.Win.UltraWinGrid
> args As
> > > > > EventArgs)
> > > > > c"),EpiUltraGrid)
> > > > > Dim dr as datarow
> > > > > Dim tURL as String
> > > > > Next
> > > > > End Sub
> > > > > -- line 78 --
> Handles
> Color.Blue
> Cursors.Hand
> > > > > End Sub
> > > > > Error: BC30506 - line 78 (154) - Handles clause requires a
> WithEvents
> > > > > variable defined in the containing type or one of its base
> types.
> > > > > ** Compile Failed. **
> > > > > [Non-text portions of this message have been removed]
