Dashboard date ranges publish & subscribe?
Thanks for the reply. That is what I did for the first grid now I want
to apply that same date range to the second grid without having to do a
double entry of date field values.
Dan
Of advantage
Sent: Tuesday, August 04, 2009 4:16 PM
Subject: Re: [Vantage] dashboard date ranges publish & subscribe?
right click; customize tracker view....highlight the date fields; there
should be in the control properties; just like customizing a
screen....This is from memory; sooo here goes...
Properties:
Tracker Query Control=Check
Dashboard Prompt-=True
Dashboard Condition=Greater than or equal to for the minimum date range
field
Dashboard Condition=Less than or equal to for the maximum date range
field
----- Original Message -----
Sent: Tuesday, August 04, 2009 5:06 PM
Subject: [Vantage] dashboard date ranges publish & subscribe?
I have a dashboard with 2 grid views and a tracker view related to the
first grid view. The tracker view contains a date range filter that I
would like to publish and subscribe the range values to the second grid
view on the dashboard. Is this possible?
Dan Shallbetter
States Electric Mfg.
Dan Shallbetter
right click; customize tracker view....highlight the date fields; there should be in the control properties; just like customizing a screen....This is from memory; sooo here goes...
Properties:
Dashboard Condition=Greater than or equal to for the minimum date range field
Dashboard Condition=Less than or equal to for the maximum date range field
Dan Shallbetter
