DAshboard Customization
I’m trying to set it up where once you input the custid and leave the field, everything auto populates without having to hit the refresh button. What method should I be trying to call to get this to work?
i’d go with a validating event in your control (probably a text box?) and then call a refresh. Many of the methods natively inside the dashboard assembly are private though you can use reflection to get to them.
    MethodInfo mi = typeof(EpiBaseForm).GetMethod("handleToolClick", BindingFlags.Instance | BindingFlags.NonPublic);
    mi.Invoke(MainController, new object[] { "RefreshTool", new Infragistics.Win.UltraWinToolbars.ToolClickEventArgs(MainController.MainToolManager.Tools["RefreshTool"], null) });
@rbucek Here is the customization that was come up with. Your piece was very helpful.
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
private EpiTextBox txtcustid;
this.txtcustid = (EpiTextBox)csm.GetNativeControlReference(“65632918-1f6c-4399-9db4-61c79e45d8ba”);
this.txtcustid.LostFocus += new System.EventHandler(this.txtcustid_LostFocus);
this.txtcustid.LostFocus -= new System.EventHandler(this.txtcustid_LostFocus);
// Begin Custom Code Disposal
	// End Custom Code Disposal
private void txtcustid_LostFocus(object sender, System.EventArgs args)
System.Reflection.MethodInfo mi = typeof(EpiBaseForm).GetMethod(“handleToolClick”, System.Reflection.BindingFlags.Instance | System.Reflection.BindingFlags.NonPublic);
mi.Invoke(MainController, new object[] { “RefreshTool”, new Infragistics.Win.UltraWinToolbars.ToolClickEventArgs(MainController.MainToolManager.Tools[“RefreshTool”], null) });
Thanks for helping out!!
