Hi Guys,
With Dashboard customization is it best to
Customize the Main controller?
Customize the tracker view inside dashboard maint?
Also is it possible via customization to refresh a baq view inside a dashboard? I have looked inside a main controller customization for a way to refresh the adapter but I have come up with zilch so far.
You should customize the deployed assembly, there are a lot of things you cannot do inside the dashboard maintenance “customization”
Yes you can refresh the dashboard from inside the customization all you need to do invoke the refresh command.
MainController.AppControlPanel.HandleToolClick("RefreshTool", new
Infragistics.Win.UltraWinToolbars.ToolClickEventArgs(MainController.MainToolManager.Tools["RefreshTool"], null));
Thanks Jose,
I don’t want to refresh the entire dash just one of the views. The problem with refreshing the entire dashboard is you loose your row and then that causes the subscriber/publisher to select a different row.
