Dashboard Compile Errors
So I created a sql view and created an external BAQ (done this many times before). The BAQ test fine and returned results. I created a dashboard and when I try to do a Test Application it get an application error. See screen shot. I did not add any tracker views to eliminate any issue.
Could this be a service pack issue? have you recently upgraded or applied a patch?
