Dashboard caption label shifted or changed by itself
On 10.2.2.4,
I have some weird thing happening to my dashboard. I consistently have to retype the Label Caption because the field change by itself when I go to the properties. Anyone got the same problem?
See the picture below, I have a Tracker View up the top there. I just go to the Properties of the Tracker View, it looks like the Column no longer line with the Label Caption. It looks like the Label Caption has been shifted …
Have you cleared your cache after making the change?
Tried clear client cache. Restarted Epicor, when I click into properties, the label will get out of sync. Tried deleting the tracker view and start again. As soon as you move the field using up and down arrow. The label will get out of sync. I think I will report this to support.
Try changing the label on the associated BAQ
Found out the problem is to do with the language. If you have language set to Australia some how the translation will help you to shift the rows label. Will report this to Epicor Support.
Hope if anyone wondering why label being shifted and will get overwritten, it is due to the language.
Thanks @TobyLai
so do you recommend to install the USA/English language only?
To fix the problem, we set our account to nothing. I think Language should not install unless you are using a language that is not english.
