Daily Production Work time
We plan to move toward using Kinetic to get our production employees work times, rather than use our outdated wall mounted punch cards for each of them.
Is there a report available to pull the daily or weekly work times for your resources?
I’m most interested in the original start clock in to MES and their final clock out at the end of the day.
They’re all good at clocking out, as we’ve had plenty of issues with labor the following day if they forget.
Any help or suggestions would be appreciated.
Thank you,
-Mike
I think that would be in the payroll module. LaborHed should get you what you want. Make a BAQ to sum the PayHours by EmployeeNum by Day for ActiveTrans = 0. You can also check the shift for planned hours versus recorded.
Then decide if you need a report or dashboard.
The Labor Edit Report shows Employee Clock-In/Out and Pay Hours. You can customize to suit your needs, and I like the Shop Tracker to see who is here and what they are working on.
Hope that helps.
