Can you use the Leave event on that text box? It will fire the instant
the user tabs or clicks outside that text box, before any data gets
updated... might be too soon for your needs.
Brian.
Of Tom J. Christie
Sent: Monday, October 08, 2012 11:49 AM
Subject: [Vantage] Customizing a Handheld screen
I am working on customizing a handheld screen and have an odd situation.
On the start production activity screen, there is a field for the jobnum
that is tied to an epicordataview called start. The underlying table
record that gets generated by the form when closed is a labordtl record.
I would like to be able to populate a few readonly textboxes when the
user leaves the jobnum textbox. If I use an afterfield change it does
not fire until the screen is closed (as the labordtl record is not
created until then). Any suggestions on how to get a OnExit event from
an Epicor base textbox?
Once I have a trigger that hits when the user leaves the field I can do
all the work of pulling the required data and populating the custom text
boxes.
Tom Christie
Manufacturing Engineer
AGM Container Controls
3526 E Ft. Lowell Road
Tucson, AZ 85716
PH: 520-881-2130
FX: 520-881-4983
www.AGMcontainer.com<http://www.agmcontainer.com/>
Brian.
Of Tom J. Christie
boxes.
Tom Christie
Tucson, AZ 85716
PH: 520-881-2130
FX: 520-881-4983
