Austin Skrepak
Data Specialist / Developer
EXT: 2019
[cid:image001.png@01CEB9F9.9CC451B0]
PO Box 280 | 1530 Western Avenue |Sheldon, IA 51201
P: 712-324-4854 | F: 712-324-4522
www.rosenboom.com<http://www.rosenboom.com/>
NOTICE: This email may contain confidential and proprietary information of Rosenboom Machine & Tool, Inc. By opening any enclosed files, the recipient agrees not to use, reproduce, disclose, or manufacture its contents, in whole or in part, without prior written consent of Rosenboom Machine & Tool, Inc.
“Whether you think you can or think you can’t, you’re right.â€
Henry Ford
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joshua Giese
Sent: Tuesday, September 24, 2013 3:32 PM
Subject: RE: [Vantage] Customized Form Opens Minimized
The other thing we have found too. Is if you use more than one computer, one with two monitors and one with one monitor personalization’s will cause this issue too. I have had to purge a few to get that to stop happening.
Josh
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of Winter, Patrick
Sent: Tuesday, September 24, 2013 3:30 PM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Are you using dual screens, use the primary monitor when you save customizations, compile dashboards, etc…..
Patrick Winter
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of askrepak@...<mailto:askrepak@...>
Sent: Tuesday, September 24, 2013 15:26
Subject: [Vantage] Customized Form Opens Minimized
We are running 9.05.702.
I edited an existing customization, simply adding a few text boxes to Job Entry. There is no custom code behind. The customization was working fine. Now when I open the form, it opens minimized. Clicking on it doesn't show the window. The only way I am able to get the form to display is if I do a right-click, maximize. Once I have the form maximized, I can minimize and maximize it with no issues, but if I restore the window, it disappears again, unable to be shown.
Has anyone ever had this issue before? This is driving me nuts!
-Austin Skrepak
