I have also set up a reference to the control and then added a event
handler to make the control's visibility false if it changes and is
true.
Many ways to accompish a task :o)
bw
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
true.
bw
wrote:
>them not
> I have set up some controls with a Width and Length of zero to make
> visible because the visible property does not override the codethat loads
> with the form.Behalf Of
> Scott
> -----Original Message-----
> pvolkert365effective
> Sent: Saturday, September 01, 2007 9:19 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Customized Form Errors
> Besides moving the control behind another control, another
> (and possibly easier) method, is to just relocate the control to aI
> point outside the box it is in. Make the X or Y axis coordinate
> large enough so the control moves out of sight. It can still be
> found in the tree view if you want to get it back. The "visible"
> property does not seem to be reliable.
> -Peter Volkert
> --- In vantage@yahoogroups.com, Fons van der Beek
> <fons.vanderbeek@> wrote:
> > I can't help you on the first problem.
> > You could take a look at the script by selecting "all code" this
> read
> > only, but it may show something that you can resolve to your
> error........
> > The second problem can be solved by a work around..............:
> > By moving the button you want to hide BEHIND another field, be
> sure to
> > set the order of the field to be hidden is behind the other field.
> > (bring forward, backward)
> > On some forms this is the only way to hide programmed in buttons
> which
> > occasionally popup.
> > You also may want to change the tab order.
> > dub554 schreef:
> > > On my custom form, I get 2 errors when loading it. The first I
> assume
> > > has to do with a Foreign Key, however, the weird thing is that
> havegoto:
> > > zero foreign keys in my Data Tools.
> > > The second involves the already programmed-in button that comes
> on the
> > > base model of most forms. I do not need this button, so I have
> > > deleted its binding, set enabled = false, and set visible =
> false.
> > > How do I get this nuisance to go away?
> > > Any input on these errors would help me greatly...
> > > 1) Error Detail
> > > Invalid FKView registration, count of Binding strings must
> > > match ValidationType from ContextMenu.xml
> > > 2) Error Detail
> > > Object reference not set to an instance of an object.
> > > Stack Trace
> > > at Epicor Mfg.UI.FrameWork.EpiUIUtils.
> > > reParentEpiButtonEpiKeyFields()
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You must have already linked your email address to a yahoo id to
> enable access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and Crystal Reports and other 'goodies', please goto:
> > > (2) To search through old msg's goto:
> > > (3) To view links to Vendors that provide Vantage services
> http://groups.yahoo.com/group/vantage/linksmust have
> > > Yahoo! Groups Links
> already linked your email address to a yahoo id to enable access. )Builder and
> Yahoo! Groups Links
