Customize Order Entry Search Screen
You can't edit a native search but you can write a BAQ that touches the tables the app uses, include all the columns you'd like to see in an order entry search, set the columns to be used in searches & then you can selectively use the BAQ search instead of the default.
If you want your BAQ search to BE the default, create a Named search based on the BAQ and set it to be the default search.
Rob
--- On Mon, 3/2/09, Scott Litzau <scott.litzau@...> wrote:
Subject: [Vantage] Customize Order Entry Search Screen
Date: Monday, March 2, 2009, 11:51 AM
I would like to customize the grid in Order Entry's Search Screen. I
have not found a way to get into customization for that screen.
Any ideas?
Scott
Any ideas?
Scott
