Customize Context Menu for epiUltraGrid
Jose,
Do you know which dll to reference to access the Infragistics ContextMenu?
Sent: Thursday, May 31, 2012 2:41 PM
Subject: Re: [Vantage] Customize Context Menu for epiUltraGrid
Then its a LOT more hairy! You need to use the ContextMenu from
Infragistics I dno't have a readly available example.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
On Thu, May 31, 2012 at 2:39 PM, Ted Koch <tkoch77@...> wrote:
> What if the field I am wanting to use the context menu with is not
> 'native' to the form I have a datagrid on po suggestion that displays all
> attachments related the part as well as attachments related to the job, the
> datagrid is populated using dynamic query. Everytime a user clicks on a new
> suggestion the datagrid gets updated. I wanted to add a right click that
> would allow them to email the attachment by automatically generating the
> email and inserting the attachment using the filepath which is in the grid.
> From: Jose Gomez <jose@...>
> Sent: Thursday, May 31, 2012 2:12 PM
> Easiest way to do it, is to add the context menu to the bound field as
> shown below
> public void InitializeCustomCode()
> // ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added
> Variable Initialization' lines **
> // Begin Wizard Added Variable Initialization
> // End Wizard Added Variable Initialization
> // Begin Wizard Added Custom Method Calls
> // End Wizard Added Custom Method Calls
> oTrans.RegisterContextHandler("OrderHed.PONum", "Click this",
> handleContextClick);
> object handleContextClick(object sender, object currentValue)
> MessageBox.Show("Current value is:Â " + currentValue.ToString() + " --
> setting to foobarbuzz");
> return "foobarbuzz";
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <
>Â <http://www.josecgomez.com/professional-resume/>
>Â <http://www.usdoingstuff.com>
> On Thu, May 31, 2012 at 2:05 PM, tkoch77 <tkoch77@...> wrote:
> > Has anyone had success with adding another option to a user added
> > UltraGrid context menu? I see you can access the ContextMenuStrip for the
> > grid, but not sure how to (if possible) to add another selection option.
> > Thanks,
> > Ted
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Has anyone had success with adding another option to a user added UltraGrid context menu? I see you can access the ContextMenuStrip for the grid, but not sure how to (if possible) to add another selection option.
Ted
shown below
MessageBox.Show("Current value is: " + currentValue.ToString() + " --
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Ted
What if the field I am wanting to use the context menu with is not 'native' to the form I have a datagrid on po suggestion that displays all attachments related the part as well as attachments related to the job, the datagrid is populated using dynamic query. Everytime a user clicks on a new suggestion the datagrid gets updated. I wanted to add a right click that would allow them to email the attachment by automatically generating the email and inserting the attachment using the filepath which is in the grid.
shown below
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Ted
*Jose C Gomez*
*Software Engineer*
E: jose@...
> shown below
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks,
> > Ted
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
I figured it was a little bit more complicated. I tried this but it create a new context menu over the standard one. It doesnt add it to the standard one that has copy to excel etc.. When I right click on the cell and click the new context menu it displays what is in that cell whcih is what Im looking for.
epiUltraGridC1.ContextMenuStrip.Items.Add("TESTING", Nothing, AddressOf cntx_Click)
   Private Sub cntx_Click(ByVal sender As Object, ByVal args As System.EventArgs)
      MsgBox(epiUltraGridC1.ActiveCell.Value.ToString)
   End Sub
*Jose C Gomez*
*Software Engineer*
E: jose@...
> shown below
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Thanks,
> > Ted
