Customization V8.03-From Supplier to Sales Order
Check out sub process menu maintenance
Of bw2868bond
Sent: 12 December 2006 21:37
Subject: [Vantage] Re: Customization V8.03-From Supplier to Sales Order
I tried it out and see what you mean. Other Customizations I have
done for 'called' forms always have called a menu item, whether it
was visible on the menu or not. This one does not. I'm afraid I do
not have an answer.
Sorry...
"laidig.systems" <laidig.systems@...>
wrote:
> I'm not sure what you mean by that. Let me explain what I have
> already done. In developer mode, i open the Sales Order Form, i
make
> a sales order and go to File>New>New Line From Quote. The window
that
> pops up is Epicor.Mfg.UI.App.SalesOrderEntry.LineFromQuoteForm and i
> have customized this for. In the Menu Maintenance, i wanted to link
> my new customization to this menu for all of the users who are not
in
> Developer Mode. I don't know what "program" in the menu
maintenance
> to link my new customization to since it was not originally in the
> menu. I can find my new customization under the SalesOrderEntry.dll
> Program but it doesn't do anything when i link my customization to
> that. I have looked in our SQL server for the table where the menus
> and customizations are stored but i can't find the correct table.
The
> only table i found was the Menu table and that just showed the
parents
> and sequence of the menus. If you need any other information, just
> let me know. Thanks so much for all your help.
"bw2868bond" <bwalker@> wrote:
> > While in developer mode, do whatever it is that calls the second
form
> > and make note of the menu id called - at least in V8.00
"laidig.systems"
<laidig.systems@>
> > wrote:
> > > I looked in the menu table in my db and there isn't any
reference to
> > > the App.SalesOrderEntry.LineFromQuoteForm. How do i find this
form
> > in
> > > my menu? I didn't see any items in the menu that were marked
with
> > > "DoNotDisplayInMenu" either. Am I looking in the wrong place?
, "bw2868bond" <bwalker@> wrote:
> > > > They *are* in the menu structure, but hidden from view. One
would
> > think
> > > > that there would be an option to view the hidden items maybe
on
> > the
> > > > Menu Maintenance actions menu. To assist in deploying
> > customizations to
> > > > the 'hidden from menu' forms.
> > > > It is possible to mess up the menu system to the point where
> > Vantage
> > > > will not launch so extreme care must be used when altering
the
> > menu
> > > > table to allow the hidden item to be un-hidden so that a
> > customization
> > > > can be specified and then re-hidden.
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007183/msg
Id=53624/stime=1165959726/nc1=3848544/nc2=3848640/nc3=3>
I am trying to write a customization that will take a supplier number
entered into the OrderDtl table in Character05 and display the Vendor
Name that was entered into the Supplier Master table. I have written
the following code. I think everything is ok with connecting to the
VendorDetail table but my problem is after the "Try" statement. Any
help would be appreciated.
Dim VendDtlAdapt As VendorAdapter = New VendorAdapter(SalesOrderForm)
VendDtlAdapt.BOConnect()
Dim soVendID As String =
edvOrderDtl.dataView(edvOrderDtl.Row)("Character05")
'msgbox("Get by ID Num: " & soVendID)
VendDtlAdapt.GetByID(soVendID)
'msgbox("Get by ID Found " & VendDtlFound)
Try
Dim dsVendDtl As EpiDataView =
CType(oTrans.EpiDataViews("VendorDetail"), EpiDataView)
Dim VendName As String = dsVendDtl.dataView(dsVendDtl.Row)("Name")
msgbox(VendName)
Catch e As Exception
msgBox(e)
Finally
VendDtlAdapt.Dispose()
End Try
It may be easier to use the 'listlookup'
do a search in help for listlookup and read through the custom
example - standard comments
You should be able to easily change the code example given to the
vendoradapter
hth
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
number
Vendor
(SalesOrderForm)
> Try
("Name")
> msgbox(VendName)
> msgBox(e)
> Finally
> End Try
That worked great. I didn't know about the ListLookUp function. Thanks!
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
So how could that work for a child key? For instance
Customer Is Key1 and Child Key is some other Number that tied to
specific Child Table Data
Would that be done in the whereclause?
> vendoradapter
> hth
> --- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@>
> number
> Vendor
written
the
Any
> (SalesOrderForm)
> > Try
> ("Name")
> > msgbox(VendName)
> > msgBox(e)
> > Finally
> > End Try
He was doing a lookup on a totally unrelated table using a value
entered into a user defined field.
You can do a listlookup on almost any BO that only takes one
whereclause parameter. The whereclause itself can have multiple
conditions...
If you have a particular lookup in mind, I will try to help...
--- In vantage@yahoogroups.com, "Michael McWilliams"
> > vendoradapter
> > hth
<laidig.systems@>
> > number
> > Vendor
> written
to
> the
statement.
> Any
> > (SalesOrderForm)
> > > Try
> > ("Name")
> > > msgbox(VendName)
> > > msgBox(e)
> > > Finally
> > > End Try
Take a look at setting up a foreign key.
I setup UD01 to have part number in key1 and I wanted to display the
part description in my UD01 Maintenance screen.
In customization --> Tools --> Data Tools you create a "Custom Column
Like" (in my case UD01.key1 is like Part.PartNum)
Create a new custom View tying UD01.key1 to Part.PartNum. The fields
are case sensitive so be careful.
When I added the Text field, The new view was a option on the Datasource
property dropdown.
Once the new view was selected and of the part fields were in the
Datafield dropdown. Chose Part description.
Save the customization.
Reload the customization from the menu and description was displayed
when a part number was entered. This required no VB code except to
make the textbox read only.
Hope I understood your requirement and hope this helps.
Dale
Of Michael McWilliams
Sent: Tuesday, December 05, 2006 2:55 PM
> vendoradapter
> hth
> number
> Vendor
written
the
Any
> (SalesOrderForm)
> > Try
> ("Name")
> > msgbox(VendName)
> > msgBox(e)
> > Finally
> > End Try
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Here is what I am trying to do. I want to pull in UD Data into
OrderDtl
I have UD110 set up. Key 1 is equal to OrderDtl.CustNumCustID
UD110A the Child Table has Child Key that is equal to
OrderDtl.Character05
I am trying to view the fields in UD110A based on the CustNumCustID &
I would appreciate any help.
> conditions...
the
> > > vendoradapter
> > > hth
> <laidig.systems@>
supplier
> > > number
the
> > > Vendor
> > written
> to
> > the
> statement.
> > Any
> > > (SalesOrderForm)
> > > > Try
(dsVendDtl.Row)
> > > ("Name")
> > > > msgbox(VendName)
> > > > msgBox(e)
> > > > Finally
> > > > End Try
I have never grasped the concept of the UD parent/child tables.
If someone could give a good example of the use of these tables I
would appreciate it :)
That being said, the UD tables pose a unique problem with using in a
base form. You can not make a foreign Key View to them using the data
tools menu. You can however cause them to appear as a dataview by
using code. There is an example in help that can be found by doing a
search for 'user preferences faqs' and then view the topic about user-
defined tables and foreign-key views
If you can't find it or have problems, reply back - I will check back
here later...
> OrderDtl
> > conditions...
to
custom
> the
> > > > vendoradapter
> > > > hth
> > <laidig.systems@>
> supplier
> > > > number
> the
> > > > Vendor
have
> > > written
connecting
> > to
> > > the
> > statement.
> > > Any
> > > > (SalesOrderForm)
> > > > > Try
> (dsVendDtl.Row)
> > > > ("Name")
> > > > > msgbox(VendName)
> > > > > msgBox(e)
> > > > > Finally
> > > > > End Try
It looks like UD110A which is the child table also holds the Key from
UD110. I can get the info easily using crystal just using UD110A
(child table) without ever looking to the Parent. If I could connect
to the Table UD110A via UD110Adapter and get the fields based off
Key1 in UD110 and ChildKey1 in UD110A it would work. I am guessing
if I could pull in the Table UD110A Via the adapter I could do
something that looks at both UD110A.Key1 and UD110A.ChildKey1.
a
data
a
user-
back
> here later...
value
> > OrderDtl
CustNumCustID
> > > conditions...
> to
> custom
to
> > the
> > > > > vendoradapter
> > > > > hth
> > > <laidig.systems@>
> > supplier
> > > > > number
display
> > the
> > > > > Vendor
> have
> > > > written
> connecting
> > > to
> > > > the
> > > statement.
> > > > Any
> > > > > (SalesOrderForm)
> > > > > > Try
> > (dsVendDtl.Row)
> > > > > ("Name")
> > > > > > msgbox(VendName)
> > > > > > msgBox(e)
> > > > > > Finally
> > > > > > End Try
You are on the correct lines,
Create data views for the two views then link them via the
setParentView method from the child.
Sent: 06 December 2006 01:36
a
data
a
user-
back
> here later...
value
> > OrderDtl
CustNumCustID
> > > conditions...
> to
> custom
to
> > the
> > > > > vendoradapter
> > > > > hth
<mailto:vantage%40yahoogroups.com> , "laidig.systems"
> > > <laidig.systems@>
> > supplier
> > > > > number
display
> > the
> > > > > Vendor
> have
> > > > written
> connecting
> > > to
> > > > the
> > > statement.
> > > > Any
> > > > > (SalesOrderForm)
> > > > > > Try
> > (dsVendDtl.Row)
> > > > > ("Name")
> > > > > > msgbox(VendName)
> > > > > > msgBox(e)
> > > > > > Finally
> > > > > > End Try
Another question i have that is somewhat related to this post is
getting information from UD01 via a combo dopdown box. I am able to
click on "Get Retriever Info" and find my "UD01ADAPTER" but the
problem is that it aways displays the Character01 feild in my
dropdown, i want it to display Key 1.
As long as you do not already have data in Character01, the easiest
solution would be to populate Character01 with the same data in Key1...
I have read in help that you can define the data returned in a
retriever, but Support did not understand my question when I asked how
and copied them on what help said....
I know, i read in help where it said you could customize the retriever
but that was it. No explanations. Anybody else know?
Another question. Is there a way to customize forms that are not
located in the menu structure? For instance, in the Sales Order
Entry, i wanted to customize the dialog box that pops up when you add
a "New Line From Quote." I was able to customize the sheet but I
can't link that customization to the sheet as default for all the
other users who aren't in Developer mode. The form i am trying to
customize is App.SalesOrderEntry.LineFromQuoteForm
They *are* in the menu structure, but hidden from view. One would think
that there would be an option to view the hidden items maybe on the
Menu Maintenance actions menu. To assist in deploying customizations to
It is possible to mess up the menu system to the point where Vantage
will not launch so extreme care must be used when altering the menu
table to allow the hidden item to be un-hidden so that a customization
I looked in the menu table in my db and there isn't any reference to
the App.SalesOrderEntry.LineFromQuoteForm. How do i find this form in
my menu? I didn't see any items in the menu that were marked with
While in developer mode, do whatever it is that calls the second form
in
think
the
customizations to
Vantage
menu
customization
<laidig.systems@>
not
you add
I
the
to
already done. In developer mode, i open the Sales Order Form, i make
a sales order and go to File>New>New Line From Quote. The window that
my new customization to this menu for all of the users who are not in
Developer Mode. I don't know what "program" in the menu maintenance
and customizations are stored but i can't find the correct table. The
only table i found was the Menu table and that just showed the parents
> in
> think
> the
> customizations to
> Vantage
> menu
> customization
not have an answer.
Sorry...
make
that
in
maintenance
The
parents
form
<laidig.systems@>
reference to
form
> > in
with
would
> > think
on
> > the
> > customizations to
> > Vantage
the
> > menu
> > customization
