Customization Update for Order Tracker
Jim,
 Sure. That shouldn't be too much effort?! :(  OR.... I could take a copy of Order Entry and make a customization that hides everything but the fields(s) I want updated. Thanks for getting back on the question. I thought the VB would open up that field independent of the read-only nature of the tracker. Good info. -Karl
Sent: Thursday, June 14, 2012 6:10 AM
Subject: [Vantage] Re: Customization Update for Order Tracker
Â
missed it on the first read. Order tracker by default is a read only transaction so you probably can't make any field writable. You could put an unbound control on the screen for the user to enter the value and then have a button to run code to do the actual write. You'd have to initialize an adapter to the order, along with a getbyid and an update separate from the current transaction. After that a otrans.refresh() to refresh the current view on the tracker.
Jim Kinneman
Encompass Solutions, Inc
--- In vantage@yahoogroups.com, Karl Dash <dashkarl@...> wrote:
> I have a UD field attached to OrderHed that gets filled in Order Entry. Now I want a very select number of users to update this field without disturbing anything else. It occurred to me to use Order tracker and let that one field be updateable. Using a customization that has been referenced in messages before and the User Guide, I put the following in InitializeCustomCode():
> Â
> '// End Custom Method Calls
> Â Â Â Â Â Â Â SetExtendedProps()
> Â Â Â Â Â End Sub
> Â
> Then before the end of the module, went the following sub:
> Â
> Private Sub SetExtendedProps()
> Â Â Â Dim edv As EpiDataView = CType(oTrans.EpiDataViews("OrderHed"), EpiDataView)Â Â Â Â
>    If edv.dataview.Table.Columns.Contains("UserDate1") Then  Â
> Â Â Â Â Â Â Â edv.dataView.Table.Columns("UserDate1").ExtendedProperties("ReadOnly") = False
> Â Â Â Â Â Â Â edv.dataView.Table.Columns("UserDate1").ExtendedProperties("Enabled") = True
> Â Â Â End If
> End Sub
> End Module
> Â
> So far, so good. It compiles with no errors, BUT the field does not show up as editable (I have used Menu Maintenance to make the customization the default for this Tracker).
> Â
> I am on Progress, 803.408. Any thoughts, comments, suggestions?
> Â
> Regards -Karl
Â
       SetExtendedProps()
     End Sub
Â
Â
   Dim edv As EpiDataView = CType(oTrans.EpiDataViews("OrderHed"), EpiDataView)   Â
   End If
End Sub
End Module
Â
Â
Â
Regards -Karl
Should "userdate1" be "UDdate01"?
Jim Kinneman
> Â
> Â Â Â Â Â End Sub
> Â
> Â
> Â Â Â End If
> End Sub
> End Module
> Â
> Â
> Â
> Regards -Karl
Jim Kinneman
> Â
> Â Â Â Â Â End Sub
> Â
> Â
> Â Â Â End If
> End Sub
> End Module
> Â
> Â
> Â
> Regards -Karl
Jim,
 No, that is a legitimate field in OrderHed. Thanks. -Karl
Sent: Thursday, June 14, 2012 6:07 AM
Â
Jim Kinneman
> Â
> Â Â Â Â Â End Sub
> Â
> Â
> Â Â Â End If
> End Sub
> End Module
> Â
> Â
> Â
> Regards -Karl
You can't do it in tracker, put a simple BPM in palce if field x change
from any to any and user not in security group XYZ then raise eror.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Jun 14, 2012 at 9:51 AM, Karl Dash <dashkarl@...> wrote:
> Jim,
> From: jckinneman <jckinneman@...>
> Jim Kinneman
> > SetExtendedProps()
> > End Sub
> EpiDataView)
> False
> > End If
> > End Sub
> > End Module
> > Regards -Karl
