Customization - Trigger from Job Traveler Print
Keith -
The reverse logic I've found easier. Create a button/program using 4GL
or .Net to run your Job Traveler and BarTender reports sequentially.
If you put it on the print Job Traveler screen the user can choose what
to print.
HTH,
Calvin Dekker
Email: calvin@...
http://www.codabears.com
<http://www.codabears.com/>
*New software/hardware Support & Maintenance Programs
Of Keith
Sent: Wednesday, October 07, 2009 7:16 AM
Subject: [Vantage] Customization - Trigger from Job Traveler Print
I need to print a label automatically each time a job traveler is
printed. The label is a bin-tag. Can I trigger 4GL code whenever a
traveler is printed using a BPM (via 4GL, i can then trigger BarTender)?
thanks!
Keith
I need to print a label automatically each time a job traveler is printed. The label is a bin-tag. Can I trigger 4GL code whenever a traveler is printed using a BPM (via 4GL, i can then trigger BarTender)?
thanks!
Keith
