Customization Script Editor Frustration
Sometimes when you are writing a customization and for no aparent reason Ctrl C, Ctrl V stops working and gets remapped to Ctrl + Insert and Shift + Insert
Has anyone found a way to restore Ctrl C and Ctrl V in these instances? It seems like once this happens, you are for ever doomed in this particular customization.
This has frustrated me for a long time. I haven’t found a way around it and I cant test it right now but what about Ctrl+B and switching the command for Copy/Paste/Cut?
Holly crap @duckor #GENIOUS I’ll give it a shot
This works! Thank you @duckor
Ctrl + B brings up this dialog
and you can assign / fix your Keyboard Shortcuts.
What?! +5 to Duckor!
I’ve been dealing with right click>copy/paste for so long…
download
I’ve noticed when that happens, CTRL-Ins / Shift-Ins still works.
Bump on this one. Ctrl+B brings up the menu, but it doesn’t seem to matter what I do, I leaves that ctrl-ins shift-ins in there. How do I get rid of those?
Now if @Duckor could just tell us how to enable the auto indent.
And what’s the diff between Tabify and Indent ?
Found it my self
Maybe try reset to default. or remove and re-assign the CTRL+C
I tried that. :frowning_face:
I think the context menu is always going to show the built-in shortcuts.
FWIW - I’ve always used Ctrl+C and Ctrl+V for copy and paste, without ever going into the Editor Key Bindings.
Also, I assigned Ctrl+Ins to another function (Print), and it changed what pressing Ctrl+Ins does. But the context menu still shows:
ĀÆ\_(惄)_/ĀÆ
Sometimes Ctrl+C and Ctrl+V work, and sometimes they don’t. I’m not sure what they are related to, but for the current customization I am working on, it will not work most of the time. Occasionally, it will, which is pretty frustrating because I know it can.
Tabify appears to convert white space to tabs, and Untabify - vice versa
My context menu shows CTRL+INS as well but CTRL+C works just fine.
Anyone know how to get it to work for me?
Make sure that Ctrl+C isn’t assigned to any other function.
Safe to assume you’ve tried:
Edit:
After using ā€œReset to defaultā€, the Clipboard.Copy function shows as:
And now it’s working fine. :rage: I wish I knew what was affecting this.
May you tell me how to get the window ā€œEditor Keys bindingā€?
My Epicor version is 101600. I am very appreciate your support.
Thank you.
