Hi Brian
Thanks your second option did it...........
So to clarify what i understand
If the subprocess uses the same dll as the parent than you have to
name the subprocess customization the same as the main form customization
If the subprocess uses his own dll (e.g. Order job Wizard) then you
have to set up the process calling maintenance
Ephraim
Ephraim
On Thu, Jun 30, 2011 at 5:07 PM, Brian Roberts <broberts@...> wrote:
> I've found two different ways to customize subforms, but I'm not clear
> on which method is required when...
> - Process calling maintenance, which it sounds like you've
> tried already.
> - Creating a customization for the main form with the same name
> as the subform, and specifying that customization in menu maintenance
> against the main form. Give that a try.
> Brian.
> Of Ephraim Feldman
> Sent: Thursday, June 30, 2011 3:56 PM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Customization on screen without menu bar
> So i customized that form
> Now i want to use it so i realised that the customisation is under The
> quote
> dll so when setting up the sub proccess and the process calling i put
> the
> quote program but it doesnt bring me up that form can someone help me
> Ephraim
> On Thu, Jun 30, 2011 at 3:34 PM, Ephraim Feldman <effgroups@...
> <mailto:effgroups%40gmail.com> >wrote:
> > ok
> > Tried it again and when i click just a drop under the title bar the
> menu
> > comes up
> > Thanks
> > On Thu, Jun 30, 2011 at 3:33 PM, Ephraim Feldman <effgroups@...
> >> Hi Jose
> >> I tried that but nothing came up
> >> On Thu, Jun 30, 2011 at 2:39 PM, Jose Gomez <jose@...
> <mailto:jose%40josecgomez.com> > wrote:
> >>> Right click :)
> >>> *Jose C Gomez*
> >>> *Software Engineer*
> >>> *checkout my new blog <http://www.usdoingstuff.com> *
> >>> *T: 904.469.1524 mobile
> >>> E: jose@... <mailto:jose%40josecgomez.com>
> >>> http://www.josecgomez.com
> >>> <http://www.linkedin.com/in/josecgomez> <
> >>> http://www.facebook.com/josegomez>
> >>> <http://www.google.com/profiles/jose.gomez> <
> >>> http://www.twitter.com/joc85>
> >>> <http://www.josecgomez.com/professional-resume/>
> >>> <http://www.josecgomez.com/feed/>
> >>> *Quis custodiet ipsos custodes?*
> >>> On Thu, Jun 30, 2011 at 2:29 PM, Ephraim Feldman
> <effgroups@... <mailto:effgroups%40gmail.com>
> >>> >wrote:
> >>> > Hi All
> >>> > Im trying to do a customisation on the Quote order wizard screen
> >>> (called
> >>> > from teh quote to create an order) but there is no menubar on that
> >>> screen
> >>> > to
> >>> > go into customization mode
> >>> > How do i do that?
> >>> > Ephraim
> >>> > [Non-text portions of this message have been removed]
> >>> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> >>> have already linked your email address to a yahoo id to enable
> access. )
> >>> (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> >>> Crystal Reports and other 'goodies', please goto:
> >>> http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/>
> >>> (2) To search through old msg's goto:
> >>> http://groups.yahoo.com/group/vantage/messages
> >>> (3) To view links to Vendors that provide Vantage services goto:
> >>> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
