Not a problem. I appreciate you staying in touch with this one.
Actually, I was able to get this to work, as you initially described,
with only a minor add-on. I did use the Part Transaction Log. But,
even though I was using an existing Sub-Process I still needed to
create a new Process Call (this information came from support). Once
that was done it worked like a champ.
Everybody is happy. Thanks for everything.
Jeff
--- In vantage@yahoogroups.com, "Daniel Laidig" <daniellaidig@...>
Jeff
wrote:
>when I told
> Ok, Sorry for the confusion. My first email was actually wrong,
> you to pick Part Transaction Log. I got it working on my end, sohere is
> what you need to do.location
> 1. Create a customization for the part transaction history tracker.
> 2. Open Sub Process Maintenance form in the Utilities menu.
> 3. Create a new ProcessID using program Type of "Non Menu Item"
> For the program put in
> "C:\client803\client\Epicor.Mfg.UI.PartTranHistTracker.dll" or your
> to Epicor dll.and called
> 4. Select your customization.
> 5. Open Process Calling Maintenance. Click New.
> 6. Called Process Reference is Epicor.Mfg.UI.PartTranHistTracker
> from can be blank and MenuID is your processID you created in step3.
>Behalf Of
> 7. Close vantage and reopen, everything should be working now.
> Daniel Laidig
> Laidig Systems, Inc.
> (574) 256-0204 ext. 229
> <mailto:daniellaidig@...> daniellaidig@...
> jplehrLog
> Sent: Wednesday, November 05, 2008 9:32 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Customization... Issue Material Transaction
>40yahoogroups.com> , "Daniel
> Daniel,
> That is my problem... I did not get it to work. The customization
> does not show when I pull the Transaction Log. Any thoughts?
> --- In vantage@yahoogroups.com <mailto:vantage%
> Laidig" <daniellaidig@>customization
> wrote:
> > No you didn't. Epicor already created the Sub Process Menu so you
> don't
> > have to set up the Calling Maintenance. If there wasn't already a
> Sub
> > Process Menu, you would have to create it and then go into the
> Calling
> > Maintenance menu and set what programs would use this
> when40yahoogroups.com> ] On
> > called. It isn't that complicated, it just isn't very intuitive.
> Glad you
> > got it working.
> > Daniel Laidig
> > <mailto:daniellaidig@> daniellaidig@
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
> Behalf OfTransaction
> > jplehr
> > Sent: Tuesday, November 04, 2008 4:32 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> LogProcess
> > Daniel... thanks. It seemed simple anough. I went into Sub
> > Maintenance and picked my customization. I logged out and back inset
> > but do not see the change. Did I miss a step?
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%
> > wrote:
> > > You need to go into Sub Process Maintenance and pick your
> > customization for
> > > the Part Transaction Log Menu. You can create a new item in the
> > sub process
> > > maintenance, and then go into process calling maintenance and
> > that up toLog
> > > call your new sub menu. Kind of messy, but it is doable. Let me
> > know if
> > > you have problems, and I can send you a screenshot.
> > > Daniel Laidig
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%
> > Behalf Of
> > > jplehr
> > > Sent: Tuesday, November 04, 2008 3:44 PM
> > > Subject: [Vantage] Customization... Issue Material Transaction
> > >the 'Actions'
> > > Vantage 8.03.406
> > > I have customized the 'Transaction Log' found under
> > menu
> > > of the 'Issue Material' screen. My customization was to
> > simply "show"
> > > 3 hidden columns. This has been saved. This is were I get lost.
> > > How do I establish this form for use? I get it when it is the
> main
> > > menu item. But coming from the 'Action' menu has got me.
> > > Thank you!
> > > Jeff
