Customization Grid - Colorize Cell
I can colorize a row in a Grid based on the value of a cell in that row with a row rule, similar to a DashBoard but in C# :
	private void CreateRowRuleMtlSugDNBTypeNum_cEquals_2( )
		RuleAction errorMtlSug_RowAction = RuleAction.AddRowSettings( this.oTrans, "MtlSug", false, SettingStyle.Error );
		RuleAction[ ] ruleActions = new RuleAction[ ] {   errorMtlSug_RowAction   };
		RowRule rrCreateRowRuleMtlSugDNBTypeNum_cEquals_2 = new RowRule( "MtlSug.DNBTypeNum_c", RuleCondition.Equals, 2, ruleActions );
		( ( EpiDataView )( this.oTrans.EpiDataViews[ "MtlSug" ] ) ).AddRowRule( rrCreateRowRuleMtlSugDNBTypeNum_cEquals_2 );
	} //   end CreateRowRuleMtlSugDNBTypeNum_cEquals_2( )
Is it possible to colorize just that cell, instead of the entire row ?
Ken Brunelli
dgv.Rows[0].Cells[0].Appearance.BackColor = Color.Red;
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=1748
If you set the RowActino to be field only and not Row it should do just that one field.
If you set BackColor manually, you’ll probably need to ensure that UseAppStyling = false;
I’m getting an error when attempting to compile : ‘Ice.Lib.ExtendedProps.RuleAction’ does not contain a definition for ‘AddFieldSettings’
I’ve checked the Business Logic Method Call Wizard to see if there is a Field Method, but I don’t see Ice.Lib.ExtendedProps listed there.
How would I set the RowAction to be field only ?
Ken
Complete stab in the dark. Try calling the following and pass the epiBinding name of the field?
	public static RuleAction AddControlSettings(EpiDataView epiDataView, string epiBinding, SettingStyle style)
