Dear Sanjeev, below mentioned issue is coming.
Application Error
Exception caught in: mscorlib
Error Detail
Message: Exception has been thrown by the target of an invocation.
Inner Exception Message: Object reference not set to an instance of an object.
Program: CommonLanguageRuntimeLibrary
Method: InvokeMethod
Client Stack Trace
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Ice.Ewa.MetadataExtractor.AssemblyLoader.TranslateCustomCode(String vdir, String assemblySubFolder, String uiappFormName, Boolean isDevMode)
Inner Exception
at DDW.ExpressionStatement…ctor(ExpressionNode expression)
at DDW.Parser.ParseStatement()
at DDW.Parser.ParseBlock(BlockStatement node, Boolean isCase)
at DDW.Parser.ParseIf()
at DDW.Parser.ParseTry()
at DDW.Parser.ParseMethod(IType type, QualifiedIdentifierExpression name)
at DDW.Parser.ParseClassMember()
at DDW.Parser.ParseClass()
at DDW.Parser.ParseNamespaceOrTypes()
at DDW.Parser.Parse(TokenCollection tokens, List`1 strings)
at Ice.Ewa.TranslationTool.TranslationEngine.parseFile(StreamReader sr, String fileName, RulesManager rules)
at Ice.Ewa.TranslationTool.TranslationEngine.TranslateCustomCode(ILaunch Sender)
