Out of the blue we have had our 2nd PC with this error that stops Epicor from running a customization.
“The customization is having compile errors. To fix the errors, launch the program in developer mode.”
If I login on that PC as administrator the problem persists.
If I login to a different PC as that user the problem is no there.
Something happens to the PC that suddenly causes this problem but nothing appears in the Windows Event Viewer.
I completely wiped any trace of Epicor from the system, rebooted and re-loaded. No Joy !
I tried rejoining the PC to the domain, no luck.
I tried replacing some interop.dll’s.
I tried re-creating the windows profile.
I ended up wiping and reloading the PC from scratch !
I am stumped how this could happen without a decent way to figure out what happened.
Can someone point me in the right direction ?
Neil
