Never mind, it was user error. I had selected the QuoteHed, instead of the OrderHed as the data source. The Q and O look a lot alike if you can't see very good! ;-)
Thanks for the response!
Craig
Craig
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> Are all the other objects on the Project screen also disabled/greyed
> out?
> You'll find that the Vantage Business Logic forces screen objects to do
> certain things. For instance if a PO is Closed or a Job is Released
> certain fields are disabled due to the status.
> If other fields are available and only your customized checkbox is
> disabled, then check the properties on that checkbox in Dev mode to
> ensure it's enabled.
> -----Original Message-----
> Of Craig Weiss
> Sent: Wednesday, May 13, 2009 3:14 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Customization, adding checkbox
> I have created a customization to add a checkbox to the Order Entry
> Header screen. The checkbox is linked to the field OrderHed.Checkbox01.
> Everything looks OK, but when I open a project, the checkbox is greyed
> out.
> I have successfully added customizations using most of the other tools,
> but this is the first time I have tried to use a checkbox. Am I missing
> something simple?
> Thanks,
> Craig
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
