Oops my bad..i seen I had an error..that should have been
Sub DestroyCustomCode() not sub initialize! Sorry...
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Rob Bucek
Sent: Monday, March 14, 2011 11:13 AM
Subject: RE: [Vantage] Customization: Add a button to search for
customer
I suppose under Sub InitializeCustomCode()
you could put [yourdatasetvariablename] = nothing
By my code it would have looked like..
dsEmpBasic = nothing
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
Sent: Monday, March 14, 2011 11:07 AM
customer
Hi Rob,
One more question. Do I have to dispose of the data set or view and if
so, how exactly?
Regards,
Linda
Behalf
Of Linda Lowney
Sent: Monday, March 14, 2011 11:05 AM
customer
Hi Rob,
Thank you very much. That worked great!!!!
Regards,
Linda
Behalf
Of Rob Bucek
Sent: Monday, March 14, 2011 10:11 AM
customer
Below is the code I used to do just that, but for the employee table..
import the customer dll's and use the customer adaptors instead of the
employee.. in customization look under tools, and object explorer to get
the syntax.. the reference to the character fields is where I am storing
the information I bring back in the current dataset. HTH..
Private Sub btnEmployee_Click(ByVal Sender As Object,
ByVal Args As System.EventArgs) Handles btnEmployee.Click
'// ** Place Event Handling Code Here **
Dim recSelected As Boolean
Dim whereClause As String = String.Empty
Dim dsEmpBasic As DataSet =
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"EmpBasicA
dapter", recSelected, True, whereClause)
If (recSelected) Then
Dim edvoprView As EpiDataView =
CType(oTrans.EpiDataViews("oprView"), EpiDataView)
edvoprView.dataView(edvoprView.Row)("Character01") =
dsEmpBasic.Tables(0).Rows(0)("EmpID")
edvoprView.dataView(edvoprView.Row)("Character04") =
dsEmpBasic.Tables(0).Rows(0)("Name")
edvoprView.Notify( New EpiNotifyArgs(oTrans,
edvoprView.Row,edvoprView.Column) )
End If
End Sub
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
Sent: Friday, March 11, 2011 2:26 PM
Subject: [Vantage] Customization: Add a button to search for customer
I need to add a button to search for a customer so that I can get
customer information into an unrelated screen. Can someone please point
me in the right direction?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
Cambridge, ON N1T 1B9
P 519 622 4040 ext. 258
F 519 622 4031
www.pridesigns.com <http://www.pridesigns.com>
Rob Bucek
FAX: (715)284-4084
Of Rob Bucek
customer
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
customer
Hi Rob,
so, how exactly?
Regards,
Linda
Behalf
Of Linda Lowney
customer
Hi Rob,
Regards,
Linda
Behalf
Of Rob Bucek
customer
End If
End Sub
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
F 519 622 4031
