Customise BAQ Report Options
Hi all,
I have created a BAQ Report and am having difficulty customizing the options. A user currently has to enter partnum and lotnum manually. However, I would like to replace initially the partnum text option with a combo populated with all parts in erp.partbin table and then hopefully as a second stage populate a second combo for lotnum with all those returned from query where partnum is equal to that entered in the first combo (I hope this is clear :slight_smile: )
Any suggestions would be really appreciated…
Thank you
Michael
I figured out the first bit by using a BAQ Combo to show all parts in PartBin. Now I’m on the second bit which I’m struggling with which is filtering a second combo based on the first BAQ Combo where part selected in first combo is used to only show the lot numbers for that given part.
Check out the follow post. There are quite a few topics on this on the forum
