Customisation-personilazation
Hi,
Thank you very much...Its working fine.
Regards,
Deepa.M
----- Original Message ----
Sent: Thursday, May 1, 2008 4:29:40 PM
Subject: [Vantage] Re: customisation-personilazation
It just means that the customization hasn't been validated yet on that
installation of Vantage. Go to System Management > Utilities >
Customization Maintenance. Search for your customization (you can
select in the Status Dropdown of the search "Not Yet Validated").
Once you found your customization, go to Actions > Validate
Customization. You should be all set to go once it validates.
--- In vantage@yahoogroups .com, Deepa <deepait_10@ ...> wrote:
> In Vantage 8.03.404,
> 1.we have tried customisation on journal entry screen, its
done and we achieved our goal, so we save it on export file.
> 2.And also imported the same xml file without developer mode, its
working fine
> The issue is actually,
> when we tried to import the same file on another system have vantage
8.03.404 installed, doesnot have such customisation on journal entry
module before, instead of coding again for that customization and we
simply import the xml file directly from the path where we copied, it
showing error such as follows:
> Layer verification failure:
> "Customisation Import Test for the application
App.GLJournalEntryF orm failed validation for build 8.03.404,
> please inform your system Administrator"
> For more information pls refer the attached document which shows the
error screen.
> If you please help for that issue, it will be more appreciated and
helpful.
> Regards,
> M.Deepa
____________ _________ _________ _________ _________ _________ _
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile. Try it now.
http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
____________________________________________________________________________________
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
1.we have tried customisation on journal entry screen, its done and we achieved our goal, so we save it on export file.
2.And also imported the same xml file without developer mode, its working fine
when we tried to import the same file on another system have vantage 8.03.404 installed, doesnot have such customisation on journal entry module before, instead of coding again for that customization and we simply import the xml file directly from the path where we copied, it showing error such as follows:
Â
Â
"Customisation Import Test for the application App.GLJournalEntryForm failed validation for build 8.03.404,
Â
Â
For more information pls refer the attached document which shows the error screen.
If you please help for that issue, it will be more appreciated and helpful.
Â
Regards,
M.Deepa
working fine
error screen.
helpful.
> Regards,
> M.Deepa
