Hi, I have added in extra tabs on the Invoice Open, Closed and Order Open and Closed by embedding a BAQ as we require more information. We have retrieval buttons for all. I have included code so when a customer is changed or the clear button is used all grids will clear, this is not working and is holding on to the last record. Below is my code, can someone point me in the right direction of how i can best write the code for clearing/changing of a customer.
// Custom code for CustomerTrackerForm
// Created: 11/10/2017 14:00:32
extern alias Erp_Contracts_BO_Company;
extern alias Erp_Contracts_BO_ARAgingTracker;
extern alias Erp_Contracts_BO_Customer;
extern alias Erp_Contracts_BO_CreditManager;
extern alias Erp_Contracts_BO_ARInvoice;
extern alias Erp_Contracts_BO_Quote;
extern alias Erp_Contracts_BO_CustCnt;
extern alias Erp_Contracts_BO_ARLOC;
extern alias Erp_Contracts_BO_CashDtlSearch;
extern alias Erp_Contracts_BO_ServiceContract;
extern alias Erp_Contracts_BO_CustShip;
extern alias Erp_Contracts_BO_CashRecSearch;
extern alias Erp_Contracts_BO_ARPromissoryNotes;
extern alias Erp_Contracts_BO_SalesOrdHedDtl;
extern alias Erp_Contracts_BO_OrderDtlSearch;
extern alias Erp_Contracts_BO_ShipDtlSearch;
extern alias Ice_Contracts_BO_DynamicQuery;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.Lib.Broadcast;
using Infragistics.Win;
using Infragistics.Win.UltraWinGrid;
using System.Reflection;
using Ice.BO;
public class Script
Epacsys epac_sr 9 Sept 2021 Upgrade to Kinetic 2021.1.8. Tidied fields on Customer - Atributes tab
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
private BAQDataView bdvCustomer;
private BAQDataView bdvInvClosed;
private BAQDataView bdvOrderOpen;
private BAQDataView bdvOrderClosed;
private DataView Customer_DataView;
private EpiBaseAdapter oTrans_customerAdapter;
this.Customer_DataView = this.Customer_Row.dataView;
this.oTrans_customerAdapter = ((EpiBaseAdapter)(this.csm.TransAdaptersHT["oTrans_customerAdapter"]));
this.Customer_DataView.ListChanged += new ListChangedEventHandler(this.Customer_DataView_ListChanged);
bdvCustomer = new BAQDataView("InvoiceHedCustTracker");
oTrans.Add("InvoiceHedCustTrackerBAQ", bdvCustomer);
bdvInvClosed= new BAQDataView("InvoiceHedCustTracker(closed)");
oTrans.Add("InvoiceHedCustTrackerClosedBAQ", bdvInvClosed);
bdvOrderOpen= new BAQDataView("CustomerTrackerOpenOrders");
oTrans.Add("CustomerTrackerOpenOrdersBAQ", bdvOrderOpen);
bdvOrderClosed= new BAQDataView("CustomerTrackerClosedOrders");
oTrans.Add("CustomerTrackerOpenClosedBAQ", bdvOrderClosed);
this.btnRun.Click += new System.EventHandler(this.btnRun_Click);
CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED();;
CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN();;
this.btnRtv.Click += new System.EventHandler(this.btnRtv_Click);
this.btnRunOrder.Click += new System.EventHandler(this.btnRunOrder_Click);
this.btnRunOrderClose.Click += new System.EventHandler(this.btnRunOrderClose_Click);
CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN();;
CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED();;
CreateRowRuleCustomerWebCust_cEquals_false();;
bdvCustomer = null;
bdvInvClosed = null;
bdvOrderOpen = null;
bdvOrderClosed = null;
this.btnRun.Click -= new System.EventHandler(this.btnRun_Click);
this.Customer_DataView = null;
this.oTrans_customerAdapter = null;
this.Customer_DataView.ListChanged -= new ListChangedEventHandler(this.Customer_DataView_ListChanged);
this.btnRtv.Click -= new System.EventHandler(this.btnRtv_Click);
this.btnRunOrder.Click -= new System.EventHandler(this.btnRunOrder_Click);
this.btnRunOrderClose.Click -= new System.EventHandler(this.btnRunOrderClose_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void CustomerTrackerForm_Load(object sender, EventArgs args)
// Add Event Handler Code
EpiBasePanel detailPanel1;
detailPanel1 = (EpiBasePanel)(csm.GetNativeControlReference("8fd5b1fa-db9e-423c-baca-4656696c859b"));
detailPanel1.Focus();
private void btnRun_Click(object sender, System.EventArgs args)
InvoiceHedCustTrackerBAQ();
EpiUltraGrid OpenInv1;
OpenInv1 = (EpiUltraGrid )(csm.GetNativeControlReference("35897ae0-bf81-4358-beaa-7b6b41599fa1"));
OpenInv1.Focus();
private void btnRtv_Click(object sender, System.EventArgs args)
InvoiceHedCustTrackerClosedBAQ();
EpiUltraGrid ClosedInv1;
ClosedInv1 = (EpiUltraGrid )(csm.GetNativeControlReference("95743524-42ab-4dbd-ad74-e6e2b347abc6"));
ClosedInv1.Focus();
private void btnRunOrder_Click(object sender, System.EventArgs args)
CustomerTrackerOpenOrdersBAQ();
EpiUltraGrid OpenOrder;
OpenOrder = (EpiUltraGrid )(csm.GetNativeControlReference("dd916e1c-3eb9-45c0-b65c-b6e1cf195da1"));
OpenOrder.Focus();
private void btnRunOrderClose_Click(object sender, System.EventArgs args)
CustomerTrackerClosedOrdersBAQ();
EpiUltraGrid OpenOrderClose;
OpenOrderClose = (EpiUltraGrid )(csm.GetNativeControlReference("9a779f20-a697-47de-b083-b045c723c111"));
OpenOrderClose.Focus();
private void InvoiceHedCustTrackerBAQ()
EpiUltraGrid grdOpenInv = (EpiUltraGrid)csm.GetNativeControlReference(“35897ae0-bf81-4358-beaa-7b6b41599fa1”);
int CustNum = 0;
if (Customer_Row.CurrentDataRow != null)
CustNum = (int)Customer_Row.CurrentDataRow["CustNum"];
string filter = "1 = 2";
bdvCustomer.dataView.RowFilter = filter;
using (DynamicQueryAdapter queryAdapter = new DynamicQueryAdapter(this.oTrans))
queryAdapter.BOConnect();
QueryExecutionDataSet dsExecute = new QueryExecutionDataSet();
dsExecute.ExecutionFilter.Clear();
dsExecute.ExecutionParameter.Clear();
dsExecute.ExecutionFilter.AddExecutionFilterRow("Customer", "CustNum", false, "=", CustNum.ToString(), Guid.Empty, null);
queryAdapter.QueryResults.Tables["Results"].Clear();
queryAdapter.ExecuteByID("InvoiceHedCustTracker", dsExecute);
bdvCustomer.dataView.Table = queryAdapter.QueryResults.Tables["Results"].Copy();
try //added
// table named results has results
grdOpenInv.DataSource = queryAdapter.QueryResults.Tables[“Results”]; // vData is a pointer to my Grid
grdOpenInv.EpiAutoFit = true; // not sure this works!
// Cleanup Adapter Reference
queryAdapter.Dispose();
catch (System.Exception ex)
MessageBox.Show(ex.ToString());
} //ends
private void InvoiceHedCustTrackerClosedBAQ()
EpiUltraGrid grdClosedInv = (EpiUltraGrid)csm.GetNativeControlReference("95743524-42ab-4dbd-ad74-e6e2b347abc6");
int CustNum = 0;
bdvInvClosed.dataView.RowFilter = filter;
queryAdapter.ExecuteByID("InvoiceHedCustTracker(closed)", dsExecute);
bdvInvClosed.dataView.Table = queryAdapter.QueryResults.Tables["Results"].Copy();
try
grdClosedInv.DataSource = queryAdapter.QueryResults.Tables[“Results”]; // grdClosedInv is a pointer to my Grid
grdClosedInv.EpiAutoFit = true; // not sure this works!
private void CustomerTrackerOpenOrdersBAQ()
EpiUltraGrid grdOrderOpen = (EpiUltraGrid)csm.GetNativeControlReference("dd916e1c-3eb9-45c0-b65c-b6e1cf195da1");
int CustNum = 0;
bdvOrderOpen.dataView.RowFilter = filter;
queryAdapter.ExecuteByID("CustomerTrackerOpenOrders", dsExecute);
bdvOrderOpen.dataView.Table = queryAdapter.QueryResults.Tables["Results"].Copy();
try
grdOrderOpen.DataSource = queryAdapter.QueryResults.Tables[“Results”]; // grdOrderOpen is a pointer to my Grid
grdOrderOpen.EpiAutoFit = true; // not sure this works!
private void CustomerTrackerClosedOrdersBAQ()
EpiUltraGrid grdOrderClosed = (EpiUltraGrid)csm.GetNativeControlReference("9a779f20-a697-47de-b083-b045c723c111");
int CustNum = 0;
bdvOrderClosed.dataView.RowFilter = filter;
queryAdapter.ExecuteByID("CustomerTrackerClosedOrders", dsExecute);
bdvOrderClosed.dataView.Table = queryAdapter.QueryResults.Tables["Results"].Copy();
try
grdOrderClosed.DataSource = queryAdapter.QueryResults.Tables[“Results”]; // vData is a pointer to my Grid
grdOrderClosed.EpiAutoFit = true; // not sure this works!
private void CreateRowRuleCustomerWebCust_cEquals_false()
// Description: WebCustUnchecked
// **** begin autogenerated code ****
RuleAction disabledCustomer_AccountConfirmed_c = RuleAction.AddControlSettings(this.oTrans, "Customer.WebCustShape", SettingStyle.Disabled);
RuleAction[] ruleActions = new RuleAction[] {
disabledCustomer_AccountConfirmed_c};
// Create RowRule and add to the EpiDataView.
RowRule rrCreateRowRuleCustomerWebCust_cEquals_false = new RowRule("Customer.WebCust_c", RuleCondition.Equals, false, ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["Customer"])).AddRowRule(rrCreateRowRuleCustomerWebCust_cEquals_false);
// **** end autogenerated code ****
private void CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED()
// Description: ClosedInvoicesClosedcase
ControlSettings myControlSettings = new ControlSettings();
myControlSettings.BackColor = System.Drawing.Color.LightGreen;
RuleAction errorInvoiceHedCustTrackerClosedBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerClosedBAQ", false, myControlSettings);
errorInvoiceHedCustTrackerClosedBAQ_RowAction};
RowRule rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED = new RowRule("InvoiceHedCustTrackerClosedBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "CLOSED", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerClosedBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_CLOSED);
private void CreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN()
// Description: ClosedInvoiceOpencase
RuleAction errorInvoiceHedCustTrackerClosedBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerClosedBAQ", false, SettingStyle.Error);
RowRule rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN = new RowRule("InvoiceHedCustTrackerClosedBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "OPEN", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerClosedBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerClosedBAQHDCase2_HDCaseStatusContains_OPEN);
private void Customer_DataView_ListChanged(object sender, ListChangedEventArgs args)
// Customer_DataView[0]["FieldName"]
// args.ListChangedType, args.NewIndex, args.OldIndex
// ListChangedType.ItemAdded, ListChangedType.ItemChanged, ListChangedType.ItemDeleted, ListChangedType.ItemMoved, ListChangedType.Reset
if (grdOrderClosed.DataSource != null)
((DataTable)grdOrderClosed.DataSource).Clear();
else
grdOrderClosed.DataSource = new DataTable();
if (grdOrderOpen.DataSource != null)
((DataTable)grdOrderOpen.DataSource).Clear();
else
grdOrderOpen.DataSource = new DataTable();
if (grdClosedInv.DataSource != null)
((DataTable)grdClosedInv.DataSource).Clear();
else
grdClosedInv.DataSource = new DataTable();
if (grdOpenInv.DataSource != null)
((DataTable)grdOpenInv.DataSource).Clear();
else
grdOpenInv.DataSource = new DataTable();
private void CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED()
// Description: Open Invoices
RuleAction okInvoiceHedCustTrackerBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerBAQ", false, myControlSettings);
okInvoiceHedCustTrackerBAQ_RowAction};
RowRule rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED = new RowRule("InvoiceHedCustTrackerBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "CLOSED", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_CLOSED);
private void CreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN()
// Description: Open Invoices OpenCase
RuleAction errorInvoiceHedCustTrackerBAQ_RowAction = RuleAction.AddRowSettings(this.oTrans, "InvoiceHedCustTrackerBAQ", false, SettingStyle.Error);
errorInvoiceHedCustTrackerBAQ_RowAction};
RowRule rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN = new RowRule("InvoiceHedCustTrackerBAQ.HDCase2_HDCaseStatus", RuleCondition.Contains, "OPEN", ruleActions);
((EpiDataView)(this.oTrans.EpiDataViews["InvoiceHedCustTrackerBAQ"])).AddRowRule(rrCreateRowRuleInvoiceHedCustTrackerBAQHDCase2_HDCaseStatusContains_OPEN);
