Customer table change from 300 to 600 versions
I noticed that the customer table no longer has the following fields:
CreditMemoITCode
MiscCashRecITCode
ARInvoiceAdjITCode
ARInvoiceITCode
and others on other tables…
This made a Dashboard having errors…needed to change the related BAQ.
Question: What would be an easy way to search all BAQ’s for the presence of those fields ? (if such endeavor is possible… )
Comment: I would have expected the conversion tools to flag the BAQ’s, Dashboards and Forms where such ‘removed’ fields would appear… But it did not in this case…
You can make a BAQ for the contents of BAQ’s!
yields
You could put criteria on QueryField table to limit it to the fields of the table you want.
edit
Interestingly enough … my BAQ has the QueryHdr table in it (even displaying a field from it) but it doesn’t appear in the results for the QueryID E10H-BAQ-Contents
Edit #2
A BAQ of just the QueryField table does show the QueryHdr entry.
Gee looks so obvious… why I have not thought of that !!! :roll_eyes:
Thanks Calvin I will give it a shot…
That’ll probably only get you the places where the field is a displayed column.
Finding how to include placses where the field is used in a calculation, is left as an exercise for the student… :wink:
