Is there a way to flag a shipment when trying to mark shipped if there is no miscellaneous charge or “shipper” billing type selected?
You would likely want to attach a pre-processing BPM on it, Run a trace on it to see if there’s another method called - I’m pretty sure it would just be the Update Method. You should be able to do this pretty much with widgets, and throw an error back to the user if you’re requiring them to add that information.
Kevin Simon
Thanks Kevin for that suggestion. I am pretty new to BPMs, would you be able to show me how I would set this up?
There’s plenty of information within the Epicor Help files and by using the search within this forum.
