DermotN
(Dermot Nolan)
August 20, 2020, 10:51am
1
Hello All,
I am looking to see if it is possible to add a Field to the “Customer Shipment Entry”
At the moment I need to have the following “Part Code” - “Description” - “Inv Ship Qty” – “Lot Number” – “Total Net Weight”
What I need to add to this is the parts HS Code – It is something that would save a lot of time for Customs….
What I currently do is – once all of the items are delivered and marked as shipped, it is copied to Excel and I add the HS Codes as needed……
Hi Dermot,
Sure, you add a User defined (UD) field to the ship detail table. Here’s a link that describes how to add UD field. Add Custom Field
Nancy
DermotN
(Dermot Nolan)
August 20, 2020, 1:44pm
3
Thank you… Will have a look a this now…
Also, if you are using Parts-On-The-Fly or real parts? If real, the “Commodity” code on the Part screen is used for the HS Code. That way you wouldn’t have to export it to set it, you could just add it to the Flow as needed.
