Customer Search Button for Customization
Perfect I totally missed that line. That is almost worse than finding the
missing semicolon in C++.
~Charlie
_____
Ross Hughes
Sent: Wednesday, November 04, 2009 11:17 AM
Subject: RE: [Vantage] Re: Customer Search Button for Customization
Charlie,
Sorry, I should have read more thoroughly.
Change the following line:
Dim edv As EpiDataView = CType(oTrans.EpiDataViews("Part"),EpiDataView)
To...
Dim edv As EpiDataView = CType(oTrans.EpiDataViews("UD100"),EpiDataView)
Ross
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of
Charlie Wilson
Sent: Wednesday, November 04, 2009 10:13 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
It is filtering the way it should.
No I'm actually doing this on a completely custom form. UD100
~Charlie
_____
Behalf Of
Ross Hughes
Sent: Wednesday, November 04, 2009 11:11 AM
Charlie,
Is the search box filtering properly?
The only time I get the unhandled exception is when a part is not open. Then
it is the -1 error.
I assume you are doing this on the Part form. If so, this code requires an
active record.
Keep me posted.
Ross
Behalf Of
Charlie Wilson
Sent: Wednesday, November 04, 2009 9:48 AM
Ross,
I keep getting unhandled exceptions after I make the Contact selection and
hit ok.
Dim recSelected As Boolean
Dim whereClause As String = "CustNum = " & nedEpiCustom1.Value & ""
Dim dsCustCnt As DataSet =
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"CustCntAdapte
r", recSelected, True, whereClause)
If (recSelected) Then
EpiDataView)
edv.dataView(edv.Row)("Number03") =
dsCustCnt.Tables(0).Rows(0)("ConNum")
edv.dataView(edv.Row)("Character02") =
dsCustCnt.Tables(0).Rows(0)("Name")
edv.Notify( New EpiNotifyArgs(oTrans, edv.Row,edv.Column) )
End If
Does something look off in my code. The contact number should be dumped into
ud100.number03 and the name of the contact into ud100.character02.
~Charlie
_____
Behalf Of
Ross Hughes
Sent: Wednesday, November 04, 2009 10:33 AM
Try just txtCustID or maybe txtCustID.Value
You also need to remove the single quotes for numeric values.
Ross
Behalf Of
Charlie Wilson
Sent: Wednesday, November 04, 2009 9:20 AM
If I have a numeric editor box how would I adjust Dim whereClause As String
= "CustID = '" & txtCustID.Text & "'" to make is spit out the number I tried
changing .text to .number to no avail.
~Charlie
_____
Behalf Of
Ross Hughes
Sent: Wednesday, October 28, 2009 12:49 PM
Drew,
It is only a matter of changing the WhereClause variable. But you need the
data to be available to use in the whereclause.
For example:
Dim whereClause As String = "CustID = '" & txtCustID.Text & "'"
This is assuming the value resides in a custom field called txtCustID and
will only work this way.
Another option: If you are using a base control on the form you will need to
convert the base control (CustID) to an object before you can use it.
If so, try this:
Dim CustomerID As EpitextBox =
ctype(csm.GetNativeControlReference("2b741e65-ebe9-426a-9423-d2bddd34323e"),
EpitextBox)
Dim whereClause As String = "CustID = '" & CustomerID & "'"
Make sure to change the GUID of the control (e.g.
GetNativeControlReference("XX-XX-XX, etc.") to the actual ID in the
properties of the control you are using.
That should do it.
Let me know if you need more.
Ross
Behalf Of
drew.pete
Sent: Wednesday, October 28, 2009 11:24 AM
Subject: [Vantage] Re: Customer Search Button for Customization
Ross,
I had been trying to get a similar customization working for some time. I
manipulated the code you posted to utilize the ShipTo search and reassociate
the ShipToNum based on the row selected in the search. It functioned
perfectly. Thank you! The only thing I was looking at doing, however, was
filtering the search by the customer's id. I'm sure it is a filter in the
list lookup. Maybe you have a quick solution? I will continue to look for it
in the meantime.
Thank you,
Drew
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Ross
Hughes" <ross.hughes@...> wrote:
> Charlie,
> That's not out of your league.
> If you have not solved this yet, here is an example of something that will
> invoke the customer search box and return the values to ud fields on the
> form.
> Just change the ud field names to your own.
> Modify as necessary.
> Private Sub btnCUSTID_Click(ByVal Sender As Object, ByVal Args As
> System.EventArgs) Handles btnCUSTID.Click
> '// ** Place Event Handling Code Here **
> Dim whereClause As String = String.Empty
> Dim dsCustomer As DataSet =
> "CustomerAdapter", recSelected, True, whereClause)
> CType(oTrans.EpiDataViews("Part"), EpiDataView)
> edv.dataView(edv.Row)("ShortChar05") =
> dsCustomer.Tables(0).Rows(0)("CustID")
> dsCustomer.Tables(0).Rows(0)("Name")
> edv.Column) )
> End If
> End Sub
> Tie this to an onclick event of a button.
> Let me know if you have any questions.
> Ross
Behalf
Of
> Charlie Wilson
> Sent: Wednesday, October 28, 2009 8:06 AM
> Subject: RE: [Vantage] Customer Search Button for Customization
> That is way out of my league maybe a drop down will work better.
> ~Charlie
> _____
Behalf
Of
> Kunal Ganguly
> Sent: Wednesday, October 28, 2009 8:51 AM
> Subject: Re: [Vantage] Customer Search Button for Customization
> I am relatively sure you should be able to do this with a VB
customization.
> You will have to use the customer search button, and based on the cust
> number it returns, write a SQL statement and then populate the form on the
> values returned by that.
> Thanks,
> Kunal
> From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesigncsw%40yahoo.com>
> yahoo.com>
> Sent: Wed, October 28, 2009 7:36:56 AM
> Subject: [Vantage] Customer Search Button for Customization
> Is it possible to program a Button to be a customer search button so that
> when you select a customer and click ok it will populate the correct
fields
> of your customization?
> ~Charlie
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail. <http://mail. <http://mail. <http://mail.
<http://mail. <http://mail.yahoo.com> yahoo.com> yahoo.com>
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups. <http://groups.
<http://groups. <http://groups.
yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/linksYahoo>
yahoo.com/group/vantage/linksYahoo! Groups Links
<http://groups. <http://groups.yahoo.com/group/vantage/files/>
<http://groups. <http://groups.yahoo.com/group/vantage/messages>
<http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>
when you select a customer and click ok it will populate the correct fields
~Charlie
I am relatively sure you should be able to do this with a VB customization. You will have to use the customer search button, and based on the cust number it returns, write a SQL statement and then populate the form on the values returned by that.
Kunal
~Charlie
Do You Yahoo!?
~Charlie
_____
Kunal Ganguly
Kunal
yahoo.com>
~Charlie
Do You Yahoo!?
Charlie,
form.
edv.Column) )
End If
End Sub
Ross
Charlie Wilson
~Charlie
_____
Kunal Ganguly
Kunal
yahoo.com>
~Charlie
Do You Yahoo!?
That is correct, I forgot that the customer search function returns the whole customer record (as a row) rather than just the customer number. Thanks Ross!
Kunal
Sent: Wed, October 28, 2009 10:09:01 AM
Charlie,
form.
Private Sub btnCUSTID_Click( ByVal Sender As Object, ByVal Args As
Epicor.Mfg.UI. FormFunctions. SearchFunctions. listLookup( oTrans,
"CustomerAdapter" , recSelected, True, whereClause)
CType(oTrans. EpiDataViews( "Part"), EpiDataView)
edv.dataView( edv.Row)( "ShortChar05" ) =
dsCustomer.Tables( 0).Rows(0) ("CustID" )
edv.dataView( edv.Row)( "Character02" ) =
dsCustomer.Tables( 0).Rows(0) ("Name")
edv.Notify( New EpiNotifyArgs( oTrans, edv.Row,
edv.Column) )
End If
End Sub
Ross
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Charlie Wilson
To: vantage@yahoogroups .com
~Charlie
_____
Kunal Ganguly
Kunal
____________ _________ _________ __
From: Charlie Wilson <foamdesigncsw@ <mailto:foamdesignc sw%40yahoo. com>
yahoo.com>
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
~Charlie
____________ _________ _________ _________ _________ __
Do You Yahoo!?
http://mail. <http://mail. yahoo.com> yahoo.com
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
Sweet I'll give that a try. I'm just not experienced with vb code in vantage
yet.
~Charlie
_____
Ross Hughes
Sent: Wednesday, October 28, 2009 11:09 AM
Charlie,
form.
edv.Column) )
End If
End Sub
Ross
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Kunal Ganguly
Kunal
yahoo.com>
~Charlie
Do You Yahoo!?
http://mail. <http://mail. <http://mail.yahoo.com> yahoo.com> yahoo.com
Ross,
I had been trying to get a similar customization working for some time. I manipulated the code you posted to utilize the ShipTo search and reassociate the ShipToNum based on the row selected in the search. It functioned perfectly. Thank you! The only thing I was looking at doing, however, was filtering the search by the customer's id. I'm sure it is a filter in the list lookup. Maybe you have a quick solution? I will continue to look for it in the meantime.
Thank you,
Drew
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
> Charlie Wilson
> ~Charlie
> _____
> Kunal Ganguly
> Thanks,
> Kunal
> yahoo.com>
> ~Charlie
> Do You Yahoo!?
Drew,
For example:
If so, try this:
EpitextBox)
That should do it.
Ross
drew.pete
Ross,
in the meantime.
Thank you,
Drew
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
Of
> Charlie Wilson
> ~Charlie
> _____
Of
> Kunal Ganguly
customization.
> Thanks,
> Kunal
> yahoo.com>
fields
> ~Charlie
> Do You Yahoo!?
have
Ross,
I interpolated the example you gave me and used
Dim whereClause As String = "CustNum='" & CustomerNum & "' AND ShipToNum <> ''"
to filter my search results and it worked beautifully.
Thank you for your help!
Drew
> Drew,
> For example:
> If so, try this:
> EpitextBox)
> That should do it.
> Ross
> drew.pete
> Ross,
> in the meantime.
> Thank you,
> Drew
> --- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@> wrote:
> > Charlie,
> > form.
> > edv.Column) )
> > End If
> > End Sub
> > Ross
> Of
> > Charlie Wilson
> > ~Charlie
> > _____
> Of
> > Kunal Ganguly
> customization.
> > Thanks,
> > Kunal
> > yahoo.com>
> fields
> > ~Charlie
> > Do You Yahoo!?
> have
You are welcome.
Thanks for the update.
Ross
drew.pete
Sent: Thursday, October 29, 2009 10:21 AM
Ross,
Drew
> Drew,
the
> For example:
to
> If so, try this:
> EpitextBox)
> That should do it.
> Ross
Of
> drew.pete
> Ross,
reassociate
it
> in the meantime.
> Thank you,
> Drew
> > Charlie,
will
> > form.
> > edv.Column) )
> > End If
> > End Sub
> > Ross
> Of
> > Charlie Wilson
> > ~Charlie
> > _____
> Of
> > Kunal Ganguly
> customization.
the
> > Thanks,
> > Kunal
> > yahoo.com>
that
> fields
> > ~Charlie
> > Do You Yahoo!?
> have
and
have
~Charlie
_____
Ross Hughes
Drew,
For example:
If so, try this:
EpitextBox)
That should do it.
Ross
Behalf Of
drew.pete
Ross,
in the meantime.
Thank you,
Drew
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
Behalf
Of
> Charlie Wilson
> ~Charlie
> _____
Behalf
Of
> Kunal Ganguly
customization.
> Thanks,
> Kunal
> yahoo.com>
fields
> ~Charlie
> Do You Yahoo!?
have
Ross
Charlie Wilson
~Charlie
_____
Ross Hughes
Drew,
For example:
If so, try this:
EpitextBox)
That should do it.
Ross
Behalf Of
drew.pete
Ross,
in the meantime.
Thank you,
Drew
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
Behalf
Of
> Charlie Wilson
> ~Charlie
> _____
Behalf
Of
> Kunal Ganguly
customization.
> Thanks,
> Kunal
> yahoo.com>
fields
> ~Charlie
> Do You Yahoo!?
have
Ross,
hit ok.
EpiDataView)
End If
~Charlie
_____
Ross Hughes
Ross
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Ross Hughes
Drew,
For example:
If so, try this:
EpitextBox)
That should do it.
Ross
Behalf Of
drew.pete
Ross,
in the meantime.
Thank you,
Drew
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
Behalf
Of
> Charlie Wilson
> ~Charlie
> _____
Behalf
Of
> Kunal Ganguly
customization.
> Thanks,
> Kunal
> yahoo.com>
fields
> ~Charlie
> Do You Yahoo!?
> http://mail. <http://mail. <http://mail. <http://mail.yahoo.com>
have
Charlie,
it is the -1 error.
active record.
Keep me posted.
Ross
Charlie Wilson
Ross,
hit ok.
EpiDataView)
End If
~Charlie
_____
Ross Hughes
Ross
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Ross Hughes
Drew,
For example:
If so, try this:
EpitextBox)
That should do it.
Ross
Behalf Of
drew.pete
Ross,
in the meantime.
Thank you,
Drew
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
Behalf
Of
> Charlie Wilson
> ~Charlie
> _____
Behalf
Of
> Kunal Ganguly
customization.
> Thanks,
> Kunal
> yahoo.com>
fields
> ~Charlie
> Do You Yahoo!?
have
~Charlie
_____
Ross Hughes
Charlie,
it is the -1 error.
active record.
Keep me posted.
Ross
Behalf Of
Charlie Wilson
Ross,
hit ok.
EpiDataView)
End If
~Charlie
_____
Behalf Of
Ross Hughes
Ross
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Ross Hughes
Drew,
For example:
If so, try this:
EpitextBox)
That should do it.
Ross
Behalf Of
drew.pete
Ross,
in the meantime.
Thank you,
Drew
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
Behalf
Of
> Charlie Wilson
> ~Charlie
> _____
Behalf
Of
> Kunal Ganguly
customization.
> Thanks,
> Kunal
> yahoo.com>
fields
> ~Charlie
> Do You Yahoo!?
have
Charlie,
To...
Ross
Charlie Wilson
~Charlie
_____
Ross Hughes
Charlie,
it is the -1 error.
active record.
Keep me posted.
Ross
Behalf Of
Charlie Wilson
Ross,
hit ok.
EpiDataView)
End If
~Charlie
_____
Behalf Of
Ross Hughes
Ross
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Ross Hughes
Drew,
For example:
If so, try this:
EpitextBox)
That should do it.
Ross
Behalf Of
drew.pete
Ross,
in the meantime.
Thank you,
Drew
> Charlie,
> form.
> edv.Column) )
> End If
> End Sub
> Ross
Behalf
Of
> Charlie Wilson
> ~Charlie
> _____
Behalf
Of
> Kunal Ganguly
customization.
> Thanks,
> Kunal
> yahoo.com>
fields
> ~Charlie
> Do You Yahoo!?
have
