Hi All, is there a way to default all customer orders to make direct? Please and thank you.
Well, the make direct is a result of the parts non-stock flag. So long as the site that is supplying the part has the part identified as non-stocked it will pull in as make direct.
If you are trying to get it so a specific customer is always non-stock and all others are socked then you could write a BPM to change the flag on the order for that specific customer.
Well i dont want it marked as non-stock. Trying to make it where every part this customer orders which is a 2-part process to make the FG always make direct.
A widget only data directive on OrderRel should be simple to do this
