Correction - use "orderhed" table, not "ordernum". "ordernum" is the identifier for sales orders.
There is something similar already in vantage for what you might be looking for. Check out the salesperson workbench under CRM, click refresh all and then go to the ALL tab under orders.
Kunal
Sent: Wednesday, March 4, 2009 7:38:37 AM
Subject: Re: [Vantage] Customer ID
Your BAQ needs to include ordernum and customer table, make sure that the join is on the custnum key. This is defined in the phrase builder.
Kunal
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Wednesday, March 4, 2009 6:28:59 AM
Subject: RE: [Vantage] Customer ID
Customer ID is the ID that everyone sees. Custnum is the actual
sequential key that Epicor uses for the customer. This allows you to
change the ID across the board as the ID is not the record key. Changing
the ID does not change the custnum.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant .com <http://www.vistaconsultant.com/> /
www.2WTech.com
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of Jonathan Lang
Sent: Tuesday, March 03, 2009 1:21 PM
Subject: [Vantage] Customer ID
Hi guys,
I have a small problem I am hoping some one has the answer too.
I am trying to create a BAQ for our Blanket Orders I have in the system
I can retrieve all of the blanket orders but the Customer ID Looks like
the Database identifier.
For example: Customer A20506 comes out as 1345 on the report. I am
thinking it is the order they were loaded into the system.
How can I get the Actual Customer number on the report.
Jonathan Lang
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Kunal
Kunal
Charlie Smith
www.2WTech.com
Of Jonathan Lang
Hi guys,
Jonathan Lang
Fax: (920) 682-7699
