Custom TextBox and DataView format
e10
customization
(Rubén Corral Yruretagoyena) #1
Hi All,
Does anybody knows if it is possible to “format” custom TextBox fields and custom Dataview columns, for example: Text Alignment centered or to the right?
Best Regards.
(Bernie Walker) #2
myTextBox.Appearance.TextHAlign = HAlign.Center;
and if you get errors you will need
using Infragistics.Win;
(Rubén Corral Yruretagoyena) #3
Thank you Bernie… that worked perfectly for the textboxes!! should you know how to center, for example, the info in a Dataview column?
(Chris Conn) #4
I think it’s this, In your grid initialize event change the layout of the grid
            YourGrid.DisplayLayout.Override.CellAppearance.TextHAlign = HAlign.Center;
Note this affects ALL cells, you can target individual cells as well. You should throw Bernie a marked solution when you get a chance.
(Dan Edwards) #5
You can do individual cells using something like this
grd.DisplayLayout.Bands[0].Columns["COLUMN NAME"].CellAppearance.TextHAlign = HAlign.Center;
