Custom Menu Blank Title 73147
Are you saying that you want to add a Maintenance Screen for your
table UD01 to the Vantage menu?
If so, here are the steps:
1. Go to: System Management -- Security Maintenance -- Menu
Maintenance
2. Navigate the menu tree on the left until the menu which you want
for your "parent" menu is highlighted.
3. Click File -- New -- New Menu.
4. Give the menu a unique ID. You can call it UD01 or UD5000 or
anything you want.
5. Type the Name that you want to appear on the Vantage menu to the
users.
6. Give it a security ID. If you are not sure what security ID to
give it, it is usually safe to give a User-defined table the same
security ID as the Parent menu.
7. The Order Sequence field is where you want it to be listed in the
Parent menu. Type 0 if you want it listed first. Type a high number
like 1000 if you always want it listed last.
8. Program Type = Menu Item.
9. Icon = Maintenance (in your case for your UD01).
10. Program: Press the Program button and find your program for
UD01 in the list. In your case, it should be this:
Epicor.Mfg.UI.UD01Entry.dll
11. Customization: After you select the correct Program, your
customization for UD01 will be available to select.
12. Save.
13. Exit Vantage then log back on to see your new menu item.
Lynn
--- In vantage@yahoogroups.com, "vantageuser13" <vantageuser13@...>
wrote:
> I will need to create a new interface with the table ud01. In my
> interface, it's a entry form. But I don't now when to create a new
> entry form ?
> Thanks
> Vantage 8.03.305
entry form ?
Vantage 8.03.305
