Thank you for the responses!!
Ok, I see the DLL's for the tables now. I've probably been in there 50 times and always looking for a specific program and never took notice of those. I think that might get me to where I want to go. Thanks again to everyone!
Regards,
Kurt
Regards,
Kurt
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> Kurt,
> Each user defined table has a DLL assembly associated with it in the client
> folder. For example, if you are going to use the UD01 table then you
> connect your menu to Epicor.Mfg.UI.UD01Entry.dll
> Once you re-login to Vantage you can open the new menu icon and find the
> starting point for your customization. This form is connected to all of the
> fields in table UD01. It also has 5 key fields to get started.
> The 10 series tables/assemblies are single table and the 100 series/tables
> are parent/child configured.
> Ross
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> iusevantage
> Sent: Thursday, September 03, 2009 10:55 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Custom Form
> Mr. Bucek,
> Thanks for your reply!
> I'm trying to get your suggestion to work, but I get an error. To have a new
> menu created, I think you need a program to tie it to, where I don't plan to
> use any current programs. I've done a fair amount of work in the Menu
> Maintenance, so I have a decent idea of how it works. I'm not intending to
> use an existing program. I would use a new table with just a few active
> fields (currently, but this might change in the future) and have a new form
> that would access this table which would end up being in a menu. It would be
> nice to have the form actually be tied to the table so the controls on the
> form could use it, but if need be, I could do any data reading/writing
> through code. I would say think of it as a new Visual Studio project where
> you start with a blank screen and add what you need. The only thing else I
> can think of is using a current form that has a minimal amount of controls,
> take this form and hide the current controls and add what I need. Then make
> this a customization and use it in the menu.
> I'm probably missing something and it's looking right at me, but I just
> can't see it. The 'Help' in Vantage isn't really helping. Does what I'm
> asking make sense? Thanks again!!
> Kurt
> --- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@> wrote:
> > Depending on what you are trying to accomplish A user define table may
> > give you what you are after. Go to menu maintenance (view help file for
> > this if not familiar) and create a new menu item based on a UD table
> > (UD01 through UD100, or even there are parent child tables).
> > Rob Bucek
> > Manufacturing Engineer
> > PH: (715) 284-5376 ext 3111
> > FAX: (715)284-4084
> > <http://www.dsmfg.com/>
> > (Click the logo to view our site) <http://www.dsmfg.com/>
> > Of iusevantage
> > Sent: Thursday, September 03, 2009 6:58 AM
> > Subject: [Vantage] Custom Form
> > I have searched and maybe I'm not searching correctly. I get so many
> > results that aren't related I haven't found anything. I have the same
> > problem on the Epicor site. Anyway, what I am trying to do is create a
> > completely custom (new) form. Is there a way to do this? Many thanks in
> > advance for your help!!
> > Regards,
> > Kurt
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
