Custom Fields in Kinetic UX
Hi there, is there anything to help with adding custom fields in Kinetic? I have added the columns via UD Column Maintenance and can see how to add them to ‘list’ views by selecting them in personalise columns however I cannot see anything on how to add them to a page and to setup what type of field it is?
I used to be able to do this in 9 and 10 easily and i know the Kinetic overlay is massively different, surely there is something around.
Any help or direction would be appreciated.
in The Epicor help it walks you through doing this
Just to clarify. Use the Active Homepage version of Kinetic, Open help and search for Application studio. Clicking on the link to that will open the application studio help web page. Then do a search for working with User Defined data. That should point you in the right direction.
If you have access to the Epicor Education that is online, I used the videos they have and found them extremely helpful.
Application Studio help is also very useful and being online it does get updated
