Custom database
Mark,
Thanks for the help! We'll give it a try.
Dave
Sent: Thursday, August 23, 2001 11:44 AM
Subject: RE: [Vantage] Custom database
Dave,
Progress will search all connected databases for the table in
question. We have not found any issues where tables are not found. We do not
prefix any of our code with the database name. Optionally you can specify
the database name when you reference a table.
Find First CdsVntg.HRDays or Find First HRdays will do the same
thing as long as HRdays is not in two different databases.
Mark CharamutD
> From: Cole, Dave [mailto:dave@...]
> Sent: Thursday, August 23, 2001 12:17 PM
> To: 'vantage@yahoogroups.com'
> Mark,
> I was told by Progress support that if I used a separate
> database there
> could be problems when I reference tables. Progress will
> look for the table
> in the database that was opened first and if it doesn't find
> it there it
> might error out. Have you had any trouble with this?
> Thanks,
> Dave Cole
> From: Mark Charamut [mailto:mrprogress@...]
> Sent: Thursday, August 23, 2001 10:49 AM
> If you add the objects into a new database there shouldn't be
> any need to
> get a custom dump and load routine. You will just need to
> make sure that you
> are only connected to the vantage database when you apply any schema
> ............................<Snip>
> ------------------------ Yahoo! Groups Sponsor
> Do you need to encrypt all your online transactions? Secure
> corporate intranets? Authenticate your Web sites? Whatever
> security your site needs, you'll find the perfect solution here!
> http://us.click.yahoo.com/Bre3tC/Q56CAA/yigFAA/PhFolB/TM
<http://us.click.yahoo.com/Bre3tC/Q56CAA/yigFAA/PhFolB/TM>
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You must have already linked your email address to a yahoo id
> to enable access. )
> Builder and Crystal Reports and other 'goodies', please goto:
<http://docs.yahoo.com/info/terms/>
<http://rd.yahoo.com/M=207641.1565480.3121573.1269402/D=egroupweb/S=17050071
83:HM/A=765263/R=0/*http://www.verisign.com/cgi-bin/go.cgi?a=b15334027000300
0>
<http://us.adserver.yahoo.com/l?M=207641.1565480.3121573.1269402/D=egroupmai
l/S=1705007183:HM/A=765263/rand=617722725>
Hi,
We are doing some custom Progress programming and have a question. We are
creating several new tables and would like to know if these tables should be
kept in a separate database or added to Vantage.db. We are going to add the
calls to our programs to the Vantage menu system.
If we set up a separate database, can we modify the Vantage.vtg file to open
this multiple database?
Are we better off adding the tables to the Vantage database making sure we
use unique table names. We could precede the name with "ud_" to show that
it is a user defined table.
I understand there are some issues with opening multiple databases.
Any help would be appreciated.
Dave
David S. Cole
Reeder & Kline
Dave,
Either method will work, but you'll get better response from Vantage Support
if you can assure them that your programs do not write AT ALL to the Vantage
database. Connecting to more that one database is a matter of creating the
entry in the services file and changing the .pf file. Here's an example:
-db x:\vantage\db\vantage.db
-N TCP -H servername -S service1name
-db x:\mydatabase\dbname.db
-N TCP -H servername -S service2name
-p x:\vantage\mainmenu.w
Steve Sanders
Delta Centrifugal Corp
Sent: Wednesday, August 22, 2001 2:29 PM
To: Vantage@...
Subject: [Vantage] Custom database
Hi,
be
the
open
Dave
David S. Cole
Reeder & Kline
Having worked with Progress for more years than I sometimes want to admit
and several different ERP packages such as Vantage, let me recommend the
following. DO NOT MODIFY THE STANDARD VANTAGE DATABASE even by adding
tables.
Keith E. Taylor
Vice President
LBSi
Information systems consulting
Specializing in Progress based ERP packages
Training, customization, programming and Business Consulting
12120 Elmwood Ave., Cleveland, OH 44111
Phone: 216-476-1416 ext 26
Fax: 216-476-1452
email: keith@...
Sent: Wednesday, August 22, 2001 3:29 PM
To: eManfacturing Yahoo Groups (Vantage@...)
Hi,
Dave
David S. Cole
Reeder & Kline
Long Business Systems, Inc.
12120 Elmwood Ave.
Cleveland, OH 44111
Phone: (216) 476-1416
Fax: (216) 476-1452
http://www.lbsi.com
Modifying the vantage database could severely hamper any future upgrades to
the database, and create billable support issues ESPECIALLY IF YOU ARE
ADDING TO OR MODIFYING THE TABLE STRUCTURE. Adding records to existing
vantage tables is one thing, but when you go to do patches, schema changes
etc. on a database with a different table structure than the patch program
expects, you could definitely run into issues.
Sent: Wednesday, August 22, 2001 3:04 PM
tables.
Keith E. Taylor
Vice President
LBSi
Fax: 216-476-1452
email: keith@...
Hi,
Dave
David S. Cole
Reeder & Kline
12120 Elmwood Ave.
Cleveland, OH 44111
Fax: (216) 476-1452
http://www.lbsi.com
According to Vantage support, this is the best way to do it. As long as you
DO NOT CHANGE any Vantage tables or fields. We would use unique table names
that Vantage would most likely never use, such as preceding the table name
with "UD_" for User Defined.
According to support, the only issue with this is when you do an upgrade,
you would need to contact support for a custom file to do the dump and load
for the new schema changes.
Dave
Sent: Thursday, August 23, 2001 9:57 AM
tables.
Keith E. Taylor
Vice President
LBSi
Fax: 216-476-1452
email: keith@...
Hi,
Dave
David S. Cole
Reeder & Kline
12120 Elmwood Ave.
Cleveland, OH 44111
Fax: (216) 476-1452
http://www.lbsi.com <http://www.lbsi.com>
<http://rd.yahoo.com/M=210949.1523302.3121208.1269402/D=egroupweb/S=17050071
83:HM/A=763786/R=0/*http://altfarm.mediaplex.com/ad/ck/1177-4458-1039-1?mpt=
998578890>
<http://us.adserver.yahoo.com/l?M=210949.1523302.3121208.1269402/D=egroupmai
l/S=1705007183:HM/A=763786/rand=497225634>
If you add the objects into a new database there shouldn't be any need to
get a custom dump and load routine. You will just need to make sure that you
changes.
The only thing you will need to do with your database is to dump and load
the database tables and definitions into a database for the current version
of Progress.
I would also recommend that when adding tables to your own database that you
prefix them with a standard code to minimize the chances that your table
name will conflict with a table added in Vantage in a future release. We
have had Epicor use table names which were present in our database and it
caused a real headache.
Mark Charamut
President
Caesar Development Services, LLC
Epicor Authorized Independent Solution Provider
mcharamut@...
www.caesardev.com
(860) 667-3540
> Sent: Thursday, August 23, 2001 11:08 AM
> As long as you
> unique table names
> the table name
> an upgrade,
> dump and load
> Dave
> From: Thad Jacobs [mailto:tjacobs@...]
> future upgrades to
> to existing
> schema changes
> patch program
> From: Keith Taylor [mailto:keith@...]
> want to admit
> recommend the
> tables.
> Keith E. Taylor
> Vice President
> LBSi
> Fax: 216-476-1452
> email: keith@...
> Hi,
> question. We are
> tables should be
> going to add the
> making sure we
> to show that
> Thanks,
> Dave
> David S. Cole
> Reeder & Kline
> You must have
> Builder and
> 12120 Elmwood Ave.
> Cleveland, OH 44111
> Fax: (216) 476-1452
> You must have
> Builder and
998578890>
Mark,
I was told by Progress support that if I used a separate database there
could be problems when I reference tables. Progress will look for the table
in the database that was opened first and if it doesn't find it there it
Dave Cole
Dave,
Mark CharamutD
> Mark,
> database there
> look for the table
> it there it
> Thanks,
> Dave Cole
> any need to
> make sure that you
> to enable access. )
