Does anyone here know how I can grab the parameters of the method being called inside a Custom Code Widget ?
Can you explain your question a little differently?
Right click in the code editor and there should be a context menu item called parameters
Sure, For example let say that I want to put some custom for the Method Directive ChangeSellingQtyMaster. This method has these parameters being passed i.e.
My question is how can I grab those parameter values inside the BPM Custom Code Widget ?
parameter name="ipSellingQuantity" type="System.Decimal"![CDATA[3333.00]]/parameter
parameter name="chkSellQty" type="System.Boolean"![CDATA[False]]/parameter
parameter name="negInvTest" type="System.Boolean"![CDATA[False]]/parameter
parameter name="chgSellQty" type="System.Boolean"![CDATA[True]]/parameter
parameter name="chgDiscPer" type="System.Boolean"![CDATA[True]]/parameter
parameter name="suppressUserPrompts" type="System.Boolean"![CDATA[False]]/parameter
parameter name="lKeepUnitPrice" type="System.Boolean"![CDATA[True]]/parameter
parameter name="pcPartNum" type="System.String"![CDATA[PRB25-IN]]/parameter
parameter name="pcWhseCode" type="System.String"![CDATA[]]/parameter
parameter name="pcBinNum" type="System.String"![CDATA[]]/parameter
parameter name="pcLotNum" type="System.String"![CDATA[]]/parameter
parameter name="pcDimCode" type="System.String"![CDATA[EA]]/parameter
parameter name="pdDimConvFactor" type="System.Decimal"![CDATA[1]]/parameter
parameter name="pcMessage" type="System.String"![CDATA[]]/parameter
parameter name="pcNeqQtyAction" type="System.String"![CDATA[]]/parameter
parameter name="opWarningMsg" type="System.String"![CDATA[]]/parameter
parameter name="cSellingQuantityChangedMsgText" type="System.String"![CDATA[]]/parameter
parameter name="CallContext" type="Ice.Bpm.Context.ContextDataSet"
THANK YOU Theodore Koch
