thanks kindly for that - I'll have a play :)
--- In vantage@yahoogroups.com, Waffqle Driggers <waffqle@...> wrote:
> I only know c#, so I can't help you with VB syntax. But there are basically
> two ways to do it.
> You can use a FKV as you mentioned. You can also just call the adapter
> directly and query for the information you need. I prefer the second method
> as it allows you to update data. If you open the Object Explorer when you're
> in Developer Mode it will give you code examples for how to do this.
> If you update the dataView, make sure to call 'Notify' on it. Otherwise it
> won't update the UI among other weirdness.
> Also, you're in luck! I found some VB code I wrote a few years back before
> we switched to c# that should help you.
> This runs on the Service Call Center form so ShipToView already exists and
> is populated. This code pulls the serial number and customer number from the
> existing dataview and uses it to query the serial number table and populate
> a gridview with all the units belonging to that customer.
> The line you are interested in is the probably:
> dsSerial = SearchFunctions.listLookup(otrans, "SerialNoAdapter",
> recSelected, False, whereClause, True, "SerialNo")
> This queries the serial number table and gives you a dataset containing the
> results.
> '// Add Custom Module Level Variables Here **
> Dim recSelected as Boolean
> Dim whereClause as String
> Dim dsSerial As New DataSet
> Dim shipToView As New EpiDataView
> Dim edvDetailView As New EpiDataView
> Dim CustNum As New Int32
> Dim ShipToNum As String
> '//Get Customer Num and ShipTo Num
> shipToView = CType(oTrans.EpiDataViews("shipToView"), EpiDataView)
> CustNum = shipToView.dataView(shipToView.Row)("CustNum")
> ShipToNum = shipToView.dataView(shipToView.Row)("ShipToNum")
> '//Create Data Set of Customer Serials and Load Grid
> whereClause= "CustNum = '" & CustNum & "' AND ShipToNum = '" & ShipToNum &
> If(recSelected) Then
> ugdEpiCustom1.DataSource = dsSerial
> ugdEpiCustom1.DataMember = ""
> End If
> On Wed, Mar 31, 2010 at 2:56 PM, Kerry_Muntz <kerry_muntz@...> wrote:
> > Hi - I'm needing some help with how to write a couple of lines of custom
> > code to extract data to a variable.
> > In the example below, I have a Button Click Event (in Part) activated set
> > of code that pulls data from Vantage EpiDataView, and writes it to a text
> > file. I'm happy with how it works, except I now want to add the field
> > CurrentRate from the CurrRate table, for the CurrencyCode = AUD.
> > I don't think I can use EpiDataView for this one can I? Do I need a foreign
> > key view? Can someone please help me out with the code with this? I expect
> > it's just a couple of lines I need to turn it into a variable. I have the
> > Epicor Tools User Guide, but can't see a relevant section.
> > Here's some of the working code that I'm already happy with:
> > Private Sub btnAustralia1_Click(ByVal Sender As Object, ByVal Args As
> > System.EventArgs) Handles btnAustralia1.Click
> > Dim edvPart As EpiDataView = CType(oTrans.EpiDataViews("Part"),EpiDataView)
> > Dim PartNum As String = edvPart.dataView(edvPart.Row)("PartNum")
> > Dim PartDescription As String =
> > edvPart.dataView(edvPart.Row)("PartDescription")
> > Dim SalesUM As String = edvPart.dataView(edvPart.Row)("SalesUM")
> > Dim UnitPrice As String = edvPart.dataView(edvPart.Row)("UnitPrice")
> > system.threading.thread.sleep(600)
> > Dim writeFile As System.IO.TextWriter = New _
> > StreamWriter("c:\vantage_custom_swap003.txt")
> > writeFile.WriteLine(PartNum)
> > writeFile.WriteLine(PartDescription)
> > writeFile.WriteLine(SalesUM)
> > writeFile.WriteLine(UnitPrice)
> > writeFile.WriteLine("EOF") '// EOF for End of File
> > writeFile.Flush()
> > writeFile.Close()
> > writeFile = Nothing
> > End Sub
> > thanks kindly
> > Kerry.
