We have Vantage and do not yet use Quote entry, but checking our TEST
system, the currency field seems to be at Header, line, summary...Header
and Summary were autofilled and had a drop down, but line had a text box
with no drop down...
Check each tab in Vista (if it is the same) and find the currency fields
- do they match what is setup? Also, I see there is a currency in
Company configuration - do you have it setup there?
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of rkbiggs
Sent: Friday, December 04, 2009 2:58 PM
To:
Subject: [Vantage] Re: Currency code error when creating new quote in E9
In Vista the currency code field is also only 4 characters. I cannot
create or change my currency code because I don't have the Currency
Management Module. I guess that's part of Financials which we don't
have. My question now is if in Vista it's only 4 characters why would I
even get this error?
When I open Currency Master Maintenance the Currency Code says "US
Dollars" and is read only. If I can't add new currency codes and can't
modify what is already here how do I fix this?
--- In
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
"Karen Schoenung" <kschoenung@...> wrote:
> Hi,
> I think I have encountered this with EDI...The data dictionary shows
the
> CurrencyCode field is only 4 characters. We have one setup as BASE,
> with the rest of the fields filled in for USD...You will find the
> currency master under Accts Receivable, setup...
> FYI,
> Karen
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
> Of rkbiggs
> Sent: Friday, December 04, 2009 2:03 PM
> Subject: [Vantage] Currency code error when creating new quote in E9
> Hello All,
> We're in the final stages of testing before making the big leap. The
one
> lingering problem I'm having is an error when creating a new quote.
> "Currency code cannot contain more than 4 characters." Has anyone else
> encountered this and if so how did you resolve it? I have a call in to
> Epicor but have not gotten a response.
