Might someone be able to evaluate the following SQL (CTE) and determine why it surpasses the maximum recursion level?
WITH
cte
Company
, DemandSeq
, DemandOrdNum
, DmdPartNum
, DemandDate
, DemandQty
, JMJobNum
, MtlPartNum
, Lvl
AS
SELECT
PDM.Company
, PDM.DemandSeq
, CAST(PDM.DemandOrdNum AS VARCHAR (20))
, PDM.PartNum AS DmdPartNum
, PDM.DemandDate
, PDM.DemandQty
, CAST(JH.JobNum AS VARCHAR (20)) AS JMJobNum
, JH.PartNum AS MtlPartNum
, 0
FROM
Erp.PegDmdMst AS PDM
INNER JOIN Erp.JobHead AS JH
ON JH.Company = PDM.Company
AND JH.JobNum = PDM.DemandOrdNum
WHERE
PDM.PartNum = '<INSERT RELEVANT PARTNUM HERE>'
UNION ALL
SELECT
PDM.Company
, PDM.DemandSeq
, PDM.DemandDate
, PDM.DemandQty
, Lvl + 1
FROM
INNER JOIN cte
ON cte.Company = JH.Company
AND cte.DemandOrdNum = JH.JobNum
SELECT DISTINCT
Company
, DemandSeq
, DemandOrdNum
, DmdPartNum
, DemandDate
, DemandQty
, JMJobNum
, MtlPartNum
, Lvl
FROM
cte
WHERE
Lvl < 3
I did try the “OPTION (MAXRECURSION 200)” as part of the statement, but that didn’t work either. I also increased the “MAXRECURSION” value to “30000” (which about 2000 shy of the hard recursion boundary), which also failed.
Usually it happens when your CTE does an infinite loop. I dont know much about that table but I needed to be very specific what level 0 is and what is it not.
It usually had to do with the 2 UNIONs being too identical.
Example:
PartMtl
UNION
PartMtl
Correct Way:
PartRev
UNION
PartMtl
* Disclaimer!!!
* This is not a real query being executed, but a simplified version for general vision.
* Executing it with any other tool may produce a different result.
with [PartRevCTE] as
(select
[PartRev].[Company] as [PartRev_Company],
(CAST('' as nvarchar(50))) as [Calculated_Parent],
[PartRev].[RevisionNum] as [PartRev_RevisionNum],
[PartRev].[AltMethod] as [PartRev_AltMethod],
(CAST(PartRev.PartNum as nvarchar(50))) as [Calculated_Child],
(0) as [Calculated_Level],
(CAST('\' + '' + '\' + PartRev.PartNum + '\' as nvarchar(500))) as [Calculated_Sort]
from Erp.Part as Part
inner join Erp.PartRev as PartRev on
Part.Company = PartRev.Company
and Part.PartNum = PartRev.PartNum
and {GetLatestApprovedRev} = PartRev.RevisionNum
where (Part.PartNum = @sPartNum)
union all
select
[PartMtl].[Company] as [PartMtl_Company],
(CAST(PartMtl.PartNum as nvarchar(50))) as [Calculated_Parent],
[PartMtl].[RevisionNum] as [PartMtl_RevisionNum],
[PartMtl].[AltMethod] as [PartMtl_AltMethod],
(CAST(PartMtl.MtlPartNum as nvarchar(50))) as [Calculated_Child],
(PartRevRecursion.Calculated_Level + 1) as [Calculated_Level],
(CAST(PartRevRecursion.Calculated_Sort + '\' + PartMtl.MtlPartNum + '\' as nvarchar(500))) as [Calculated_Sort]
from PartRevCTE as PartRevRecursion
inner join Erp.PartMtl as PartMtl on
PartRevRecursion.PartRev_Company = PartMtl.Company
and PartRevRecursion.Calculated_Child = PartMtl.PartNum
and PartRevRecursion.PartRev_RevisionNum = PartMtl.RevisionNum)
select
[PartRevCTE].[PartRev_Company] as [PartRev_Company],
[PartRevCTE].[Calculated_Parent] as [Calculated_Parent],
[PartRevCTE].[PartRev_RevisionNum] as [PartRev_RevisionNum],
[PartRevCTE].[PartRev_AltMethod] as [PartRev_AltMethod],
[PartRevCTE].[Calculated_Child] as [Calculated_Child],
(((select top (1)
[LatestApprovedRev2].[RevisionNum] as [LatestApprovedRev2_RevisionNum]
from Erp.PartRev as LatestApprovedRev2
where (LatestApprovedRev2.Approved = true)
and (LatestApprovedRev2.Company = PartRevCTE.PartRev_Company and LatestApprovedRev2.PartNum = PartRevCTE.Calculated_Child)
order by LatestApprovedRev2.EffectiveDate Desc))) as [Calculated_ChildRevisionNum],
[PartRevCTE].[Calculated_Level] as [Calculated_Level],
(REPLACE(REPLACE(PartRevCTE.Calculated_Sort, '\\', '\'), '#', '')) as [Calculated_Hierarchy]
from PartRevCTE as PartRevCTE
order by Hierarchy
I have seen some funny data in the pegging files. in some cases I have found that i didn’t fully understand the way that the pegging worked. I would encourage you to pick one job/part and follow the pegging to understand how it is linked.
You never gave the recursive cte a termination condition. Move the where clause from the outer query into the second select of the cte (and change to Lvl + 1 < 3) and it should kick out of the loop after only a couple of level iterations rather than running forever and trying to filter after the fact.
WITH
cte
Company
, DemandSeq
, DemandOrdNum
, DmdPartNum
, DemandDate
, DemandQty
, JMJobNum
, MtlPartNum
, Lvl
AS
SELECT
PDM.Company
, PDM.DemandSeq
, PDM.DemandDate
, PDM.DemandQty
, 0
FROM
WHERE
UNION ALL
SELECT
PDM.Company
, PDM.DemandSeq
, PDM.DemandDate
, PDM.DemandQty
, Lvl + 1
FROM
INNER JOIN cte
WHERE (Lvl + 1) < 3 -- Termination Check
SELECT DISTINCT
Company
, DemandSeq
, DemandOrdNum
, DmdPartNum
, DemandDate
, DemandQty
, JMJobNum
, MtlPartNum
, Lvl
FROM
cte
--WHERE
-- Lvl < 3
