Crystal Syntax Help
Hi Dustin,
You can use a simple formula to calculate how many 'values' along the
string your 4-digit number is:
Value index = Integer(Position in string / 5) + 1
For example, the value index of 4187 in the string "4185~4186~4187~4188"
= Integer(11 / 5) + 1
= Integer(2.2) + 1
= 2 + 1
= 3
Or, the value index of 4188 in the string "4185~4186~4187~4188"
= Integer(16 / 5) + 1
= Integer(3.2) + 1
= 3 + 1
= 4
All you need to do is use the correct Crystal syntax (I think someone
mentioned the Crystal function InStr() which will cover the Position in
string element of the formula).
I hope this helps,
Andy Watts.
________________________________________
Behalf Of melissa hietala
Sent: Thursday, June 17, 2010 11:53 AM
Subject: [Vantage] Crystal Syntax Help
I have a string in the following format in crystal:
There is anywhere from 1 to 10 values in the string.
Say I would like to find the placement of the string "4187" in this
string. How would I return a value of 3? (being that "4187" is held in
the 3rd position of this string)
Hope this makes sense and any help is appreciated.
Dustin Biniek
Andy Watts
IT Manager
Ripley Engineering Ltd
Tel: 01256-473940/464167
Mob:
www.ripley-eng.co.uk
I have a string in the following format in crystal: "4185~4186~4187~4188"
Say I would like to find the placement of the string "4187" in this string. How would I return a value of 3? (being that "4187" is held in the 3rd position of this string)
 Dustin Biniek
Here's an example:
local stringvar x :="4185~4186~4187~4188";
local numbervar i:=0;
local numbervar FoundI;
for i := 0 to ubound(split(x,"~"))-1 do
if split(x,"~")[i+1]="4187" then FoundI:=i+1
FoundI
Of melissa hietala
Dustin Biniek
Sean,
Very cool! This gets me half way there. Now I need to take the "position" that is returned from this statement, and find this same "position" in another statement that is setup the same way and return the value.
Example:
local stringvar x :="4185~4186~4187~4188";Â
When looking for string "4187" this returns a value of 3.
I need to take a second statement:Â "16~20~23~35"
Find the 3rd position (this is what we found in the previous statement), and return the value that is seen here.
So ultimately I would need to retrieve the value 23.
Any more thoughts on how that could be accomplished????
Thanks so much
Dustin Biniek
Sent: Thu, June 17, 2010 11:13:15 AM
Subject: RE: [Vantage] Crystal Syntax Help
Â
Here's an example:
FoundI
Of melissa hietala
Dustin Biniek
local stringvar x1:= "16~20~23~35";
if ubound(split(x1,"~"))>=FoundI then split(x1,"~")[FoundI] else "different array sizes"
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Sent: Thursday, June 17, 2010 12:41 PM
Subject: Re: [Vantage] Crystal Syntax Help
Sean,
Example:
I need to take a second statement: "16~20~23~35"
Thanks so much
Dustin Biniek
From: Sean McDaniel <smcdaniel@... <mailto:smcdaniel%40comtecsolutions.com> >
Here's an example:
FoundI
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of melissa hietala
Dustin Biniek
Works like a charm. Thanks for your help!
Â
Sent: Thu, June 17, 2010 11:50:05 AM
Â
Sean,
Example:
Thanks so much
Dustin Biniek
Here's an example:
FoundI
Of melissa hietala
Dustin Biniek
Dustin,
Without some deep coding getting, returning a "3" since 4187 is the third "chunk" in that string will be difficult.
You can, however, very easily get the string position of 4187 with the InStr() function.
Hit F1 in Crystal Reports and search for InStr().
That should get you close.
Â
 Dustin Biniek
Dustin,
This will return 3
stringvar YourString;
stringvar array YourArray;
numbervar i;
stringvar StringToSearchFor;
numbervar Location;
YourString := "4185~4186~4187~4188";
StringToSearchFor := "4187";
YourArray := split(YourString,"~");
for i := 1 to ubound(YourArray) do
if YourArray[i] = StringToSearchFor then
Location;
Hth,
Linda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Thursday, June 17, 2010 12:09 PM
Cc: kevmel822@...
Dustin,
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of melissa hietala
Dustin Biniek
Â
Use the Split Function in Crystal and specify the number in the array process, this will return the value you need.
Â
Syntax
Â
split("Your String","~")[3]
Â
Doma.
Â
Date: Tuesday, June 22, 2010, 12:26 PM
Â
Dustin,
This will return 3
numbervar i;
numbervar Location;
Location;
Hth,
Linda
Cc: kevmel822@...
Dustin,
Dustin Biniek
